Üzenetek/Posts: 1049
Honk Dátum/Date: Hétfő, 2013-09-02, 21:54 | Üzenet/Post # 161
I am able to make the problem almost go away if I slow it way down. The picture on the left is done with M11P1 / M10P1 commands and the right picture is with the C-0,0001 / C0.0000 the IPM is at 25 I turned up the heat for the shadow to show right side and it is to hot for the rest. also the left side I am still able to see the same problem although it is quite small. The Acceleration is 2.5 and Velocity at 100 the Mach3 Version is R3.043.062
details laser power CHINA ???? see picture. I have mounted a cooling fan to the top of the laser power supply. I can see real good what it is doing but I haven't got a clue what to do about it. I suspect that the laser power supply needs to have a adjustment with a 9 lb. hammer
Thanks Jerry
Csatolások/Attachments: 6286409.jpg(56.1 Kb) · 8265818.jpg(56.1 Kb)
picengraver Dátum/Date: Hétfő, 2013-09-02, 22:10 | Üzenet/Post # 162
Your acel. seems on the slow side to me.  What happens when you increase it?
On my belt drive machine (similar to your's), I'm running 150 velocity and 100 acel. with some reserve left.
Hozzáadva (2013-09-02, 22:10)
Hide the hammer  smile
Honk Dátum/Date: Kedd, 2013-09-03, 01:44 | Üzenet/Post # 163
Look Look Look at this!!!!
What you said made a difference I'm at 120 and 30 and that is maxed out, unless I change my kernel speed but I don't know what I'll be getting into.
Thank you
PS: I got about 16 extra butterflies, if you need any.
Csatolások/Attachments: 7306157.jpg(86.2 Kb)
Az üzenetet módosította/Modified by Honk - Kedd, 2013-09-03, 01:53
picengraver Dátum/Date: Kedd, 2013-09-03, 11:38 | Üzenet/Post # 164
The best yet.  Looks like it's time to switch to flowers now.  biggrin
Hope it is all good from now on.
tweakie Dátum/Date: Szerda, 2013-09-04, 13:02 | Üzenet/Post # 165
Hi Jerry,
Because you still had the problem running the Butterfly at high speed when using the M11P1/M10P1 command set, this indicates to me that your laser is definitely not turning off quick enough. Running this test rules out it being anything to do with the PEP settings so it is perhaps time to review your electrical connections.
How is your parallel port laser trigger pin connected to your laser PSU ?.
Is it a direct connection or do you have other things connected to it ?
Honk Dátum/Date: Szerda, 2013-09-04, 20:46 | Üzenet/Post # 166
Hi Tweakie
John pointed out that my Acceleration and Velocity might be to slow. When I turned it up things started working good. I have it maxed out in Mach3 for my machine without changing the Kernel speed. It is a lot slower than Johns machine but it is a lot better now ( 120 velocity 30 Accel. ). The M11P1/M10P1 and the C-0.0001/C0.0000 command set will run at speeds between 50 and 100 IPM now. I have been using this speed and changing the laser amps to control the darkness of the project. I am not sure how high I can run the laser tube but I have been trying to keep it below 10 M-Amps. I think I will try the Mill picture once more to see if it has improved.
Thanks for your help.
Honk Dátum/Date: Szombat, 2013-09-07, 14:04 | Üzenet/Post # 167
John I have the forum working again.
This took about 3 1/2 hrs. and I used 50 IPM it is done on a 3D background it's 20 inches X 12 1/2 PEP4 is starting to be a real treat to work with!! I love it.
Thanks Jerry
Csatolások/Attachments: 8641804.jpg(121.5 Kb)
tweakie Dátum/Date: Szombat, 2013-09-07, 15:28 | Üzenet/Post # 168
Excellent work Jerry. respect
picengraver Dátum/Date: Szombat, 2013-09-07, 16:14 | Üzenet/Post # 169
Thank you, Jerry,
I'm very happy to see your progress and share in your success in some small way.
Now, not to be overly critical, but it appears that you are getting excessive smoke residue on your image.  Adjusting/changing your smoke extraction system should give you even better images.
Again, congratulations on your achievements.  BTW, you should also post your video of your fantastic clock project on the forum, too.
Honk Dátum/Date: Szombat, 2013-09-07, 23:23 | Üzenet/Post # 170
You won't have to look at this one anymore (maybe) but I just wanted you to see how it came out with a frame and I need to thank you all for all your help.
Csatolások/Attachments: 4057121.jpg(164.0 Kb)
picengraver Dátum/Date: Vasárnap, 2013-09-08, 00:39 | Üzenet/Post # 171
Stunning, Jerry, simply stunning.  respect
tweakie Dátum/Date: Vasárnap, 2013-09-08, 07:05 | Üzenet/Post # 172
As John says, stunning work indeed Jerry.
I am really pleased for you - it has been a bumpy road getting there but your persistence has paid off in the end.
picengraver Dátum/Date: Kedd, 2013-09-17, 23:36 | Üzenet/Post # 173
Where have you been.  Quiet here lately.  Waiting to see your latest.
I did this one today with some development software I'm playing around with.  Size is only 3.7" x 4.5".  Took 39 minutes, a big improvement over what it used to take.
Csatolások/Attachments: 2283816.jpg(201.6 Kb)
tweakie Dátum/Date: Szerda, 2013-09-18, 06:42 | Üzenet/Post # 174
Excellent John, 39 minutes sounds great - what feed-rate were you using ?
picengraver Dátum/Date: Szerda, 2013-09-18, 13:24 | Üzenet/Post # 175
Thank you, Tweakie.
Blended feed rate was about 90ipm average.
tweakie Dátum/Date: Szerda, 2013-09-18, 13:30 | Üzenet/Post # 176
That is a really good performance John - I have to admire your skills with this software development - keep up the good work my friend. smile
Amatőr Dátum/Date: Szerda, 2013-09-18, 17:58 | Üzenet/Post # 177
John, that come out very fine! Seems like the original picture was just turned into a sepia, not easy to say the difference.
JJWMACHINECO Dátum/Date: Csütörtök, 2013-09-19, 18:45 | Üzenet/Post # 178
Dual 445nm laser diode running at a set feedrate of 225IPM, .004" pixel resolution @ half power. Engraving is 9" X 7.2" and took 1hr 35 mins. Based on my 1W mini laser engravers power and performance, this build is outputting 8W+ by intersecting the 2 beams.
Csatolások/Attachments: 6813005.jpg(122.0 Kb)
picengraver Dátum/Date: Péntek, 2013-09-20, 00:50 | Üzenet/Post # 179
Jeff,
Good Show. respect Thinking as I type (dangerous, I know crazy ), I am wondering if you could remove the red pointer laser and replace it with a third laser, would the power be too much for the machine?
I ran a quick test this evening with my new PEP development software to measure shading improvements.  The wood is cheap utility ply that burns rather easily, but has a darker color than birch ply.  I will do more testing with different settings  and better wood to see if shading will improve even more.  I'm confident it will.
Csatolások/Attachments: 8386990.jpg(178.5 Kb)
Honk Dátum/Date: Péntek, 2013-09-20, 02:26 | Üzenet/Post # 180
I'm still here, just little unavailable. My darling wife drug me out of the shop for vacation. I am starting to develop shop-withdrawals and I probably will need to be trained. I be ck soon.
