PicDither - PicEngrave - PicLaser.
Dátum/Date: Vasárnap, 2013-06-23, 06:44 | Üzenet/Post # 1 |
Anything relating to - PicDither - PicEngrave - PicLaser etc. |
Honk |
Dátum/Date: Szombat, 2014-11-15, 01:11 | Üzenet/Post # 761 |
Jeff that's beautiful. Good job!! Thanks Jerry |
Dátum/Date: Szombat, 2014-11-15, 06:56 | Üzenet/Post # 762 |
Excellent job Jeff - that tin looks so real you could pick it up.
btw. excellent work with the instructable - I haven't read the new step 12 yet, but I will check it out later.
JJWMACHINECO |
Dátum/Date: Szombat, 2014-11-15, 13:10 | Üzenet/Post # 763 |
Thanks guys!
picengraver |
Dátum/Date: Szombat, 2014-11-15, 20:11 | Üzenet/Post # 764 |
Jeffery, Message received!
Hozzáadva (2014-11-15, 20:11) --------------------------------------------- Idézet Honk (  ) My latest Great job, Jerry. Stay out of the white stuff laying on the ground. John
Az üzenetet módosította/Modified by picengraver - Szombat, 2014-11-15, 20:12 |
Honk |
Dátum/Date: Kedd, 2014-11-18, 22:52 | Üzenet/Post # 765 |
I have the 45 deg.working finely, now I have to figure out how to clean it up. My latest, Diode 2W, PR .005, 75 IPM, 35% of FRC, 45 deg. , PEP4, More selective with areas of white lacquer, 12 "X 13" first time with Alder wood. I lost my Zero on the and to reset the encoder. You can see what it was doing on the antler on the top left. I also lower my acceleration in Mach3, thinking it softened Might need to set the bit (Loosing steps,?,?,?). Jerry Does any one need some of this white stuff in my yard? I have some to spair.
Az üzenetet módosította/Modified by Honk - Kedd, 2014-11-18, 22:58 |
JJWMACHINECO |
Dátum/Date: Szerda, 2014-11-19, 22:52 | Üzenet/Post # 766 |
No white stuff wanted here Jerry. It was in the low 20's in North Florida this morning. Buuurrrr
It came out very good, except for the antler that got snagged in some spider webs.
Is your stepper that drives the encoder getting too hot and loosing it's magnetism grip causing lost steps? I had that happen before.
Honk |
Dátum/Date: Szombat, 2014-11-22, 19:12 | Üzenet/Post # 767 |
My latest, Diode 2W, PR .005, 65 IPM, 35% of FRC, Horizontal. PEP4, More selective with areas of white lacquer, 22 X 32" Poplar wood. I'm going to start being more selective with the different shades on the Poplar, it sure showed up on this one. Thanks Jerry
JJWMACHINECO |
Dátum/Date: Kedd, 2014-12-16, 21:17 | Üzenet/Post # 768 |
Both were done on a LazerBlade using PicEngrave Pro 5 and gcode streamed with PicSender. 85IPM, 45 degree, .007" PR, 200 max & 10 min PWM setting on Poplar.
This is an unpaid advertisement and was approved by me.
Dátum/Date: Szerda, 2014-12-17, 06:58 | Üzenet/Post # 769 |
Nice work Jeff.
Dátum/Date: Szerda, 2014-12-17, 17:44 | Üzenet/Post # 770 |
Really nice looking burnings!
picengraver |
Dátum/Date: Szerda, 2014-12-17, 17:51 | Üzenet/Post # 771 |
Well done Jeff. Proof you really can turn a "sow's ear into a silk purse." John
JJWMACHINECO |
Dátum/Date: Csütörtök, 2014-12-18, 13:49 | Üzenet/Post # 772 |
Thank you everyone,
having loads of fun playing with a new toy that we did not have to build our-self. Well, some assembly was required.
JeffHozzáadva (2014-12-18, 13:49) --------------------------------------------- EmBlaser in action.
Doug |
Dátum/Date: Hétfő, 2014-12-22, 15:15 | Üzenet/Post # 773 |
Üzenetek/Posts: 47
Great work Jeff. You continue to amaze me.
And a Very Merry Christmas to One and All during this very special season!
Doug |
Dátum/Date: Hétfő, 2014-12-22, 17:26 | Üzenet/Post # 774 |
Jeff, congrats! Your machine works fine. I'm surprised that a diode laser can be so fast.
JJWMACHINECO |
Dátum/Date: Hétfő, 2014-12-22, 18:12 | Üzenet/Post # 775 |
Thank you Doug and Amator,
I'm impressed with the EmBlaser's ability to laser engrave photos and it runs on a modified version of grbl 9. It outputs PWM to vary the intensity using SXXX commands. No need for any expensive CNC controller programs.
Az üzenetet módosította/Modified by JJWMACHINECO - Hétfő, 2014-12-22, 23:51 |
picengraver |
Dátum/Date: Szerda, 2014-12-24, 10:11 | Üzenet/Post # 776 |
My great grandson - age 10 months. Engraved with my Emblaser machine on artist canvas using PEP5 and PicSender.
Merry Christmas to One and All. John Champlain
Dátum/Date: Szerda, 2014-12-24, 13:24 | Üzenet/Post # 777 |
Nice work John.
Dátum/Date: Szerda, 2014-12-24, 14:25 | Üzenet/Post # 778 |
John, congratulations! Very realistic work.
Honk |
Dátum/Date: Szerda, 2014-12-24, 23:00 | Üzenet/Post # 779 |
John and Jeff Nice job ! You guys are moving faster than I can keep up. I don't know EmBaser and I'm still using PEP4 Bata and what is PIC Sender. I am trying to upgrade the computer on my laser BOOM BOOM!!CRACKEL BOOM. I think I'm down for a bit. Slow down Thanks Merry Christmas and Happy New Year. Jerry |
JJWMACHINECO |
Dátum/Date: Szerda, 2014-12-24, 23:29 | Üzenet/Post # 780 |
Hi Jerry,
The EmBlaser is one of these and our PicSender program is what streams the Gcode to a grbl controller instead of using a program like Mach3. grbl is flashed (programmed) to an Arduino UNO for controlling 2-3 stepper motors on a CNC machine. The EmBlaser uses X&Y for position and outputs PWM to vary the intensity of the Laser Diode to engrave shades. It uses a S0-S255 commands for the 8bit power levels.
https://www.kickstarter.com/project....ription
Doug and Jerry. When you two have time go here and register, if you wish to.
Forum
Merry Christmas everyone.
