PicDither - PicEngrave - PicLaser.
Dátum/Date: Vasárnap, 2013-06-23, 06:44 | Üzenet/Post # 1 |
Anything relating to - PicDither - PicEngrave - PicLaser etc. |
Tp |
Dátum/Date: Szombat, 2014-11-01, 12:31 | Üzenet/Post # 741 |
Üzenetek/Posts: 19
Thanks, Jerry No, no one has mentioned it yet...
Give me some example of how you may use this....
Have you been working on anything lately??
tony |
Honk |
Dátum/Date: Szombat, 2014-11-01, 13:24 | Üzenet/Post # 742 |
Tony I use it to adjust for speed and settings When I am Trying to get something on the burn. it will help if you are using the DAC or the Encoder BECAUSE the black will end in the white or white on black will end if They are not set to Zero right. Yes I am working on the Old Train 2FT X 2FT I'll show if it does not turn into firewood. I use to work with steel but I found out mistakes will not hurt your shop keep the worm. Jerry |
Tp |
Dátum/Date: Szombat, 2014-11-01, 13:41 | Üzenet/Post # 743 |
Üzenetek/Posts: 19
Okay, thanks tony |
Tp |
Dátum/Date: Vasárnap, 2014-11-02, 03:01 | Üzenet/Post # 744 |
Üzenetek/Posts: 19
The photo of old wagon and wheel in Grove Oklahoma I used Atkinson at 65ipm on the left 1.75w the right 1w .007 ....
At least it's not all burned up
tony
Honk |
Dátum/Date: Vasárnap, 2014-11-02, 17:19 | Üzenet/Post # 745 |
Tony's looking good. Try something for me. Use test strips hurt I sent it Should Be in about 1/2" X 4" It is a .jpg. don't Dither (Just like it comes) PEP set Like shown. You don't have to run it all, see if it looks like it is on your computer. You can uncheck the edge if you want. If your machine explodes and will not stop sparking we probably have invented perpetual motion. Let me know? I'm only curious about dither, I don't use it for my diode laser only for my CO2 laser. Jerry
picengraver |
Dátum/Date: Vasárnap, 2014-11-02, 21:05 | Üzenet/Post # 746 |
Hey Jeff, Look out! Tony's moving fast into competitive mode.
Great Tony. Keep the pressure on Jeff. John
Tp |
Dátum/Date: Hétfő, 2014-11-03, 17:02 | Üzenet/Post # 747 |
Üzenetek/Posts: 19
Thanks Jerry and John for the encouragement
Sure Jerry, I'll run that tomorrow...
tonyHozzáadva (2014-11-03, 17:02) --------------------------------------------- Jerry, Picnegraver would not open that greyscale test image you sent... And Photoshop didn't recognize it either...
How did you handle it after it was sent to you
tony |
Honk |
Dátum/Date: Hétfő, 2014-11-03, 19:13 | Üzenet/Post # 748 |
Tony I put my mouse on it (right on the screen) and right click, select save as, make sure it is a .jpg and harm the desk top is selected, click Save. Then I find it on my desk top and put it the where it needs to go. I hope this Helps. If not email me I'll send it to you direct. jerry@oldcharms.com Thanks Jerry check out my web page http://www.oldcharms.com
Az üzenetet módosította/Modified by Honk - Hétfő, 2014-11-03, 19:15 |
Tp |
Dátum/Date: Kedd, 2014-11-04, 20:00 | Üzenet/Post # 749 |
Üzenetek/Posts: 19
Jerry, Okay that worked, I will run that tomorrow morning...
btw....I checked out your web site, very nice and that's a nice set up you have....
tonyHozzáadva (2014-11-04, 20:00) --------------------------------------------- Here you go Jerry, this is what I got ran it just like you had it set up
tony |
Tp |
Dátum/Date: Kedd, 2014-11-04, 20:10 | Üzenet/Post # 750 |
Üzenetek/Posts: 19
Jerry This is what I got ran it just like you had it set up no dithering
tony
Hozzáadva (2014-11-04, 20:10) -------------------------------------------
Az üzenetet módosította/Modified by Tp - Kedd, 2014-11-04, 20:11 |
Tp |
Dátum/Date: Kedd, 2014-11-04, 20:12 | Üzenet/Post # 751 |
Üzenetek/Posts: 19
This is Buddy,
dithered Atkinson
Honk |
Dátum/Date: Szerda, 2014-11-05, 00:32 | Üzenet/Post # 752 |
Thanks Tony That did not work, and now I'm more confused than ever. But what your doing is looking good, keep it up. Thanks again Jerry |
Honk |
Dátum/Date: Csütörtök, 2014-11-06, 02:48 | Üzenet/Post # 753 |
MY latest with white lacquer my next one with lacquer I will only paint in the areas I want lighter. 24" X 24" Poplar, Feed Rate 45 I(PM., .005 Pixel Resolution, Horizontal, 3 Z Heights Programs 5/8 deep 3D, barn wood frame. Thanks Jerry
Tp |
Dátum/Date: Csütörtök, 2014-11-06, 04:02 | Üzenet/Post # 754 |
Üzenetek/Posts: 19
Jerry, that looks really nice, you didn't do that with co2?? what program are you using to generate G code for your 3D |
Honk |
Dátum/Date: Csütörtök, 2014-11-06, 14:04 | Üzenet/Post # 755 |
Hi Tony I use BobCad Art Program for the router, PEP4 for the laser, Paint Shop Pro X6 for the graphics . No that's a 2 Watt Diode Laser. Thanks Jerry |
JJWMACHINECO |
Dátum/Date: Csütörtök, 2014-11-06, 14:21 | Üzenet/Post # 756 |
Excellent work Jerry,
Did you use our program to divide up the large file?
Honk |
Dátum/Date: Csütörtök, 2014-11-06, 17:39 | Üzenet/Post # 757 |
Hi Jeff I did not need it because I had to build It with three smaller files to adjust the Z height for the focus height on Z axis. I have tried it and will use it soon. Thanks Jerry |
Honk |
Dátum/Date: Péntek, 2014-11-14, 16:48 | Üzenet/Post # 758 |
My latest Diode 2 W, PR .005, 65 IPM, 35% FRC, Horizontal, PEP4, More selective with areas of white lacquer, Poplar wood. I finely figured out what was causing my white lines. There was a loose spring that tracks one of my X axis bearings. Now I'll try that 45 deg. again and maybe I'll see what it's suppose be looking like. Jerry
Dátum/Date: Péntek, 2014-11-14, 17:24 | Üzenet/Post # 759 |
As always, excellent work Jerry.
JJWMACHINECO |
Dátum/Date: Péntek, 2014-11-14, 22:46 | Üzenet/Post # 760 |
That is absolutely outstanding.
Here is an engraving I did today on our Shapeoko on the other end of the complexity spectrum of yours Jerry, but it was done for a special friend that takes my Badgering him in stride.
I don't know if anyone has followed our instructables, but we added Step 12 to it where we 3D laser diode engraved in some Poplar and shaded it also all in one pass.
http://www.instructables.com/id....er-Phot
Az üzenetet módosította/Modified by JJWMACHINECO - Szombat, 2014-11-15, 19:20 |
