tweakie Dátum/Date: Péntek, 2014-08-08, 07:46 | Üzenet/Post # 661
That's great news John ok
Wishing you all (John, Jeff & Son) every success in this new venture, which I am sure will take off very well indeed.
JJWMACHINECO Dátum/Date: Péntek, 2014-08-08, 10:50 | Üzenet/Post # 662
Thanks John for your very nice announcement of our venture together.
Thank you too Tweakie.
We have some new software ideas that we are all working together on and my son has been designing a new web site for all our Pic products.
Doug Dátum/Date: Szombat, 2014-08-09, 22:13 | Üzenet/Post # 663
Üzenetek/Posts: 47
Congratulations!!  Y'all will make a great team.  Congratulations!!
Had a photo I took of my mom on 4th of July, my dad's birthday; both 91.  Not the greatest quality photo and I'm no expert in photoshop and did not take a lot of time to adjustments/cleanup.  Made some adjustments then sharpened 10 in PEP and let it run.  Think have my laser about as close tuned in as I can expect and now focusing on photo requirement/looks for good burn.  This is not the best, however was pleased with the initial test result.  Burned at 80 ipm, 0.006" PR, horz across grain, 30% FRC, about 7.5" wide by 7" high, birch ply.
Csatolások/Attachments: 7621805.jpg(129.6 Kb)
Honk Dátum/Date: Szombat, 2014-08-09, 23:01 | Üzenet/Post # 664
Congratulations To you all, you-all. I'll be keeping an eye on what you are putting together. and thanks for all the help
picengraver Dátum/Date: Vasárnap, 2014-08-10, 23:31 | Üzenet/Post # 665
Tweakie,
Thank you for your kind words.  I am excited to be able to work more closely with Jeff and his son.
Doug,
You really have that tuned in well.  I know your mom was very pleased with your work.  Excellent. respect
Thanks for your well wishes.  Keeping up with Jeff has always been a little challenging for me, and now even more so with his son added in.  smile
They are really good associates to have.  I only wish they lived closer than 5 hours to me.  I would learn a lot more, I'm sure.
Az üzenetet módosította/Modified by picengraver - Vasárnap, 2014-08-10, 23:34
JJWMACHINECO Dátum/Date: Hétfő, 2014-08-11, 17:01 | Üzenet/Post # 666
Thanks guys for the great big congrats.
Doug, I'm still struggling to catch up with you. I needed to get my accels up higher then 70 without loosing steps, so I ordered a longer and higher in/oz nema 17 for the Z axis. It would have been a bigger project to change over to a nema 23. It should be here today and I will be up and running again soon.
Doug Dátum/Date: Kedd, 2014-08-12, 00:08 | Üzenet/Post # 667
Üzenetek/Posts: 47
Jeff, don't know how important the 4th axis is to you on your mini.  As you know, I originally setup my machine to your proven design.  However with the higher power diode I was having major problems with burn quality.  Think you noted same with your change to a different diode.  My control box that holds the LD and other electronics is rather large and I thought that it could be part of the problem with the rapid Z movements.  As I had no immediate plans to use 4th axis for rotary, easiest change was to move encoder to 4th using a nema 23 (same 23 as on X and Y).  Left the 2:1 pulleys  on Z and adjusted steps to get 1:1 measurement.  Once set Z to zero, it does not move during engraving.  With my steps/inch I have all axis (X, Y, Z, A) set at 85 accel without losing steps.  Velocity is at 105.  Could go higher on X and Y but limited on A due to steps/inch.   It was quick and easy to do this change.  Whenever I decide to do the rotary, then will do the 17 to 23 mod on Z but don't expect anytime soon.  I also have found using the simple led probe I made a quick and easy way to set Z zero.
Post a photo of your conversion when you complete it.  Interested to see your new setup.
PEP is great now -  wonder what great works to follow with the John / Jeff and Jeff team.
Doug
JJWMACHINECO Dátum/Date: Kedd, 2014-08-12, 02:16 | Üzenet/Post # 668
Doug,
The 4th axis is very important for the mini and I will never change the way it is. I plan on engraving on some round stock on it in the near future. I have another machine coming and plan to mount the encoder on it the same way. It's an Arduino UNO controlled 3 axis machine.
I'm very happy with how the encoder performs mounted to the Z axis. It just made a worlds record for the longest lasting analog modulated laser diode photo engraving machine to date.  I should call Guinness. laugh
Yes, I ran into some issues with higher speeds and power, but I can ensure you, it will be resolved soon.
Az üzenetet módosította/Modified by JJWMACHINECO - Kedd, 2014-08-12, 11:08
JJWMACHINECO Dátum/Date: Kedd, 2014-08-12, 18:15 | Üzenet/Post # 669
Finally. 75IPM, 30% FRC, .006" PR, vertical across grains, no gamma and sharpen to 20. Accels on all three axis's are set to 90 now. The line going across the top is a seam in the Birch Ply.
Csatolások/Attachments: 0127286.jpg(101.8 Kb)
Doug Dátum/Date: Kedd, 2014-08-12, 21:33 | Üzenet/Post # 670
Üzenetek/Posts: 47
Absolutely great!
JJWMACHINECO Dátum/Date: Kedd, 2014-08-12, 22:23 | Üzenet/Post # 671
Thanks Doug,
I'm on a roll and I felt this one was needed. 80IPM, 25% FRC, .006" PR, no gamma change, sharpened to 12, 45 degree left and full power.
Csatolások/Attachments: 1514621.jpg(99.0 Kb)
picengraver Dátum/Date: Szerda, 2014-08-13, 01:11 | Üzenet/Post # 672
Jeff,
What a great tribute to one of the best comedians I ever watched and enjoyed.  So sad.
Honk Dátum/Date: Péntek, 2014-08-15, 02:36 | Üzenet/Post # 673
Well I finely got my web page almost done, now what do I do with it?
Here is my latest achievement, I am running a little faster now and I finely have a handle on Pixel Resolution. This one is at 90 IPM and .007 pixel resolution and 35% feed rate change. I painted this with investable light It is 30 inches X 23 inches. By the way this is where I live and they finely got the street paved.
Thanks Jerry
Csatolások/Attachments: 5110608.jpg(134.4 Kb)
picengraver Dátum/Date: Péntek, 2014-08-15, 10:23 | Üzenet/Post # 674
As always Jerry, your work is excellent.  hands
I hope you don't mind, but I am posting the link to your web site so all can see it.
http://www.oldcharms.com/
Doug Dátum/Date: Hétfő, 2014-08-18, 21:30 | Üzenet/Post # 675
Üzenetek/Posts: 47
Jeff/John,  ran the Jimmy Stewart pic today.  Ran 4 hrs without any lost steps.  Reviewed the code for the file noted in my email.  All appears well, however when I run it the 'A' stepper loses steps.  Got a ghost somewhere.  Just going to discard as can not duplicate with other photos.  Only thing change in the Jimmy Stewart was I ran at 80 ipm instead of 75.
Csatolások/Attachments: 6434438.jpg(343.9 Kb)
JJWMACHINECO Dátum/Date: Hétfő, 2014-08-18, 23:01 | Üzenet/Post # 676
WOW Doug,
that came out excellent and you squeaked by me 5 IPM faster too.   respect
tweakie Dátum/Date: Kedd, 2014-08-19, 09:13 | Üzenet/Post # 677
Ditto what Jeff has said - excellent work Doug ok
JJWMACHINECO Dátum/Date: Péntek, 2014-09-05, 23:15 | Üzenet/Post # 678
Just finishing up another build. This time a Shapeoko 2, Arduino UNO R3, grbl shield with a 9MM Nichia, MA3 encoder and a Flexmod P3. I used PicEdit Lite, PicLaser Lite and PicSender to engrave this image. I have allot of fine tuning still to do, but it's progressing.
Check out our new web site.
www.picengrave.com
Csatolások/Attachments: 9712390.jpg(101.2 Kb) · 7735538.jpg(76.5 Kb) · 0396113.jpg(98.8 Kb)
Doug Dátum/Date: Szerda, 2014-09-10, 23:38 | Üzenet/Post # 679
Üzenetek/Posts: 47
Jeff, Great work as always.  Been wondering what you were up to.  Today I think I discovered a solution to one of my problems.  If you recall, recently I had a file that the stepper A-axis stepper would lose steps when I ran it.  Then I would run a different file and all would run well without any step lost.  Today was doing a scan test photo and the lost step problem came back.  Think have found my problem.  I scanned the photo, did some minor editing in Photoshop CS6 with adjustment layers, then saved as .jpg file.  Loaded into PEP (sharpened, etc.) and generated g-code.  A-axis stepper lost steps.  Reduced acceleration but did not solve problem.  I then went back to Photoshop and loaded photo, then merged the layers prior to saving the .jpg.  Then to PEP for processing.  Ran 3.5 hours without any lost steps.  Must be something with saving a photo from Photoshop without merging layers that PEP does not like.
BTW, that little type on the right is me, 71 years ago.  The little cute gal on the left with the knobby knees is my bride.
Doug
Csatolások/Attachments: 0370465.jpg(92.1 Kb)
Honk Dátum/Date: Csütörtök, 2014-09-11, 20:19 | Üzenet/Post # 680
The Pelican is on scrap popular wood and I had a little oops with Mach3. The file was 15 + million lines and it ran out of memory in at Mach 13 + million. Its 30 X 30 inches at .005 resolution at 60 IPM, Took two days to burn. I'm burning it 3D now hope it works. John let me know how to fix it and it's perfect thank you John. It did not miss a line. Might have wormed up the machine before I started there was a Slightly lighter area at the start but no one would know if I did not show it. Oh Jeff, I'm starting to get your encoder figured out. I'm going to do this 3D one with the Diode and not the CO2 it will be the first.
Thanks again
Csatolások/Attachments: 4191053.jpg(215.9 Kb)
Az üzenetet módosította/Modified by Honk - Csütörtök, 2014-09-11, 20:31
