picengraver Dátum/Date: Hétfő, 2013-10-07, 00:06 | Üzenet/Post # 201
Jeff,
The Einstein has to be a "Polaroid" - Right? biggrin
Seriously, my congratulations.  You have finally achieved your quest for "black and white" photo quality.
tweakie Dátum/Date: Hétfő, 2013-10-07, 06:53 | Üzenet/Post # 202
Excellent work Jeff.
What type of paint are you using, is it anything special ?
JJWMACHINECO Dátum/Date: Hétfő, 2013-10-07, 12:19 | Üzenet/Post # 203
Thanks Tweakie,
It's just cheap Red Devil brand spray paint from Family Dollar. $1.40 a can. It says fast drying, but even after a few hours it's still tacky.
tweakie Dátum/Date: Hétfő, 2013-10-07, 12:58 | Üzenet/Post # 204
Thanks Jeff, as soon as I get the time I am going to give this a try - Ill let you know how it goes.
Pabló Dátum/Date: Hétfő, 2013-10-07, 19:16 | Üzenet/Post # 205
JJWMACHINECO
Jeff was very good!
Perhaps part of the solution could be a little more?
No random little video about it?
Pabló
JJWMACHINECO Dátum/Date: Hétfő, 2013-10-07, 21:11 | Üzenet/Post # 206
Thanks Pablo,
I'm not quite sure how to answer your question, but if it was not for John (Picengraver) I would not be able to get the excellent results I am getting. This new process he came up with to have both analog and varying feedrate combined on the same line of g-code has resolved all of my problems engraving on different materials. It gives me more flexibility to control the burning of the material with the laser diode.
Sometime in the future, I will make a video showing how I engrave on white paint using this process.  up
Pabló Dátum/Date: Hétfő, 2013-10-07, 22:23 | Üzenet/Post # 207
JJWMACHINECO
Thank you in advance for Jeff!
Video you'd like to see.
Pabló
JJWMACHINECO Dátum/Date: Szerda, 2013-10-09, 21:57 | Üzenet/Post # 208
Csatolások/Attachments: 9332624.jpg(92.4 Kb)
Az üzenetet módosította/Modified by JJWMACHINECO - Csütörtök, 2013-10-10, 02:38
picengraver Dátum/Date: Csütörtök, 2013-10-10, 02:19 | Üzenet/Post # 209
ok
Amatőr Dátum/Date: Csütörtök, 2013-10-10, 07:22 | Üzenet/Post # 210
Jeff, that is amazing quality!
JJWMACHINECO Dátum/Date: Csütörtök, 2013-10-10, 15:09 | Üzenet/Post # 211
Idézet Amatőr ()
Thank you John & Amator.  up
Az üzenetet módosította/Modified by JJWMACHINECO - Csütörtök, 2013-10-10, 18:13
Honk Dátum/Date: Szombat, 2013-10-12, 22:01 | Üzenet/Post # 212
These are two of my Grand Children. I was able to speed things up to 50 IPM on these two but I am having a little problem lining the laser cut up with my router cut (the laser and router are different machine). I'll get it someday, I think.
Csatolások/Attachments: 6472027.jpg(140.7 Kb) · 1893773.jpg(119.0 Kb)
Az üzenetet módosította/Modified by Honk - Szombat, 2013-10-12, 22:06
tweakie Dátum/Date: Vasárnap, 2013-10-13, 07:00 | Üzenet/Post # 213
Hi Jerry,
Excellent work with these composites, I an certain you will succeed in getting perfect alignment between your router and laser, it's just a matter of time smile
picengraver Dátum/Date: Csütörtök, 2013-10-17, 02:07 | Üzenet/Post # 214
I did these two images today with my development version of PicEngrave Pro for a comparison test.  The bottom image was engraved with a 45° left angle - the top with horiz.  Other settings same for both images - 90 ipm, 0.005" resolution, 40% feed rate change, 1.8 amps max LD power, both about 6" x 5".  I'm still analyzing a reason for the difference I see in the two, but the bottom one seems sharper to me.
Csatolások/Attachments: 8260909.jpg(218.0 Kb)
Az üzenetet módosította/Modified by picengraver - Csütörtök, 2013-10-17, 02:11
tweakie Dátum/Date: Csütörtök, 2013-10-17, 08:21 | Üzenet/Post # 215
Excellent John. ok
Interesting to see the difference - there has to be a reason but discovering it may be illusive.
Just a thought...
With all parameters being set the same the blended feed-rate may be different - did they both take a similar amount of time to complete ?
picengraver Dátum/Date: Csütörtök, 2013-10-17, 12:01 | Üzenet/Post # 216
Thanks Tweakie,
It may be partly a blended feed rate issue, I forgot to check the time on the horizontal image, but I think it was less.  Jeff suggests a beam shape/orientation possibility, too.
I'm using a "new" lens that Jeff discovered a while back.
http://cgi.ebay.com/ws....US:1123
Looking with a magnifying glass, scan lines are sharp and distinctive in the angle engraved image, but "fuzzy" in the horizontal angle one.  I estimate the width of the beam with the new lens is .003".  I have more testing to do, but I'm currently thinking that wood grain direction (horizontal in both images) may also be a contributing factor.
JJWMACHINECO Dátum/Date: Péntek, 2013-10-18, 17:53 | Üzenet/Post # 217
John,
Here is the same test and image and I got the same results as you. When you use the 45% option, the burn lines are closer then the set PR which makes the engraving darker and sharper. These were done on my mini engraver and the first one was done left 45 degrees. Second one was done Horizontal. Both were at 45IPM, .007" PR with 30% VFR.
Csatolások/Attachments: 2321406.jpg(110.5 Kb) · 7185161.jpg(101.3 Kb)
Az üzenetet módosította/Modified by JJWMACHINECO - Péntek, 2013-10-18, 19:31
Amatőr Dátum/Date: Péntek, 2013-10-18, 19:25 | Üzenet/Post # 218
Jeff, both of them is fine, but I like the first one more.
picengraver Dátum/Date: Péntek, 2013-10-18, 22:10 | Üzenet/Post # 219
Jeff,
Thanks for confirming my findings.  I'll do some more experimenting tomorrow.
Here is a reduced size copy of the original for comparison.
Csatolások/Attachments: 6530216.jpg(90.7 Kb)
picengraver Dátum/Date: Vasárnap, 2013-10-20, 00:42 | Üzenet/Post # 220
Engraved today.  Used 45° right angle option, 0.007" resolution, 95 ipm max, 30% feed rate change.
Csatolások/Attachments: 1320164.jpg(97.3 Kb)
