Tangential Knife blade holder.
Dátum/Date: Péntek, 2012-07-13, 06:31 | Üzenet/Post # 1 |
I needed a new blade holder for a tangential knife which would enable relatively quick and easy blade change and positional setup. With just a couple of hours to spare, whilst another CNC job was running, this was the result.
Dátum/Date: Péntek, 2012-07-13, 08:10 | Üzenet/Post # 2 |
tweakie, nice work again! That's why so good if You have machines to create a useful part from a piece of metal. What do You plan to cut with this tool? Will it be a vinyl cutter?
Dátum/Date: Péntek, 2012-07-13, 16:45 | Üzenet/Post # 3 |
Hi Amator,
There is a gasket material which I am unable to laser cut so thought this may do the job. It will need a little help and although I have never used ultrasonics before, how hard can it be ??
This is the Sonotrode it will be mounted to.
richy92 |
Dátum/Date: Péntek, 2012-07-13, 17:06 | Üzenet/Post # 4 |
Hi Tweakie! This is a very beautiful and great work.I'm congratulations. |
Dátum/Date: Vasárnap, 2012-07-15, 09:26 | Üzenet/Post # 5 |
Thanks Richy.
The Sonotrode dimensions have been calculated on the assumption that sound will travel through this particular grade of aluminium at 5100m/sec. If that is not the case then it is back to the drawing board.
Dátum/Date: Szombat, 2012-07-28, 11:23 | Üzenet/Post # 6 |
As it’s all part of the same project I thought perhaps these pics of the bearing housing may be of interest.
Stage 1 was to centre drill the 6 holes and (1mm undersize) profile the bore on the mill. Stage 2 was turning the OD on a lathe. Stage 3 was manually drilling and tapping the 6 holes and finishing the bore to a bearing fit.
Dátum/Date: Vasárnap, 2012-07-29, 08:58 | Üzenet/Post # 7 |
tweakie, nice work again! The closest ultrasonic thing to me is a little cleaner, I don't know too much about them. This sonotrode is new for me, I was looking for infos on the net, but I cannot see exactly how they work. What I could figure out that the shape of this part is very important to send the energy to the work area. You still need an ultrasonic generator plus a head to create the waves don't You? How will this cut through the material with a micron size stroke? Very interesting project, I'm curious for continuation!
Dátum/Date: Vasárnap, 2012-07-29, 09:18 | Üzenet/Post # 8 |
Hi Amator,
I am 'learning as I go' and fortunately have plenty of time before the project needs to be completed so plenty of margin for 'trial and error'
Initial testing will be with a 2 element transducer (like they fit to the cleaning baths) but a 4 element device will be used with the finished design. With luck, I will have some spare time next week to make some more parts
Dátum/Date: Vasárnap, 2012-07-29, 09:28 | Üzenet/Post # 9 |
tweakie, good luck to the tests! I'm waitig the results.
Dátum/Date: Vasárnap, 2013-02-24, 12:10 | Üzenet/Post # 10 |
Hi Amator,
It has been a while but the project was put on hold soon after it was started.
The good news is that the company producing the dies for cutting the gaskets did a re-think on it's pricing for the design change modifications.
The bad news is that Mach3 has a problem with it's Tangential Control tool-path generation. Once this is fixed it is likely that the project will be back on again.
