CO2 Lasers.
Dátum/Date: Hétfő, 2017-12-11, 08:03 | Üzenet/Post # 581 |
Hi Amator,
I think you are right sir, programming skills may be required - Perhaps we should give SquiggleDraw a miss
Dátum/Date: Hétfő, 2017-12-11, 08:31 | Üzenet/Post # 582 |
Just to see how it performed I did create a Mach3 Laser toolpath for the SquiggleDraw example - the Gcode would take about 50 minutes to run and I have not yet had time to try it. Unfortunately the Gcode file is just too large to attach here but if anyone wants it then, for the next 30 days, it can be downloaded from here; squiggle5
Dátum/Date: Kedd, 2017-12-12, 05:31 | Üzenet/Post # 583 |
Wait a minute! You got to a gcode from a picture? How did You do it?
Dátum/Date: Kedd, 2017-12-12, 06:48 | Üzenet/Post # 584 |
Hi Amator,
The SquiggleDraw example is in .svg format and this can be converted to .dxf and in turn Gcode. Example; squiggle6.zip
Dátum/Date: Kedd, 2017-12-12, 09:31 | Üzenet/Post # 585 |
tweakie, I thoght You found the way how to use SquiggleDraw
Dátum/Date: Kedd, 2017-12-12, 15:40 | Üzenet/Post # 586 |
Until we don't find a programmer who can explain the useage we have to freeze this promising project.
Dátum/Date: Szerda, 2017-12-13, 10:45 | Üzenet/Post # 587 |
Hi Amator,
SquiggleDraw is not difficult to use. Please try this...
Run; SquiggleDraw.pde
Click; Get Started
Menu; Sketch / Import Library... / Add Library... Select; ControlP5 Install. Close window.
Menu; Sketch / Run
Have fun.
(Your saved .svg file can be converted to Gcode in Inkscape or other CNC vector software such as Aspire9).
Dátum/Date: Szerda, 2017-12-13, 12:00 | Üzenet/Post # 588 |
A .dxf of Adele; squiggles7.zip
The Mach3 Laser Gcode; squiggles8.zip
Dátum/Date: Szerda, 2017-12-13, 21:34 | Üzenet/Post # 589 |
tweakie, thank You again! It just works. Playtime
Dátum/Date: Péntek, 2017-12-22, 07:51 | Üzenet/Post # 590 |
I am really not quite sure why anyone would want to laser engrave a photographic image onto a piece of wood in the first place but, trust me, once bitten it does become addictive.
This was an 8 bit image, raster scanned, where the laser output power is controlled by the individual pixel value converted to a PWM duty cycle signal (0 - 100%).
Dátum/Date: Péntek, 2017-12-22, 16:40 | Üzenet/Post # 591 |
Tweakie, great outcome! (I know the addiction too)
Dátum/Date: Péntek, 2019-10-25, 11:13 | Üzenet/Post # 592 |
Now I have discovered UCCNC
