CO2 Lasers.
Dátum/Date: Szombat, 2017-09-09, 10:16 | Üzenet/Post # 561 |
Different wood, different effect.
Dátum/Date: Szombat, 2017-09-09, 18:49 | Üzenet/Post # 562 |
tweakie, I think the left is birch but what wood is on the right?
Dátum/Date: Vasárnap, 2017-09-10, 06:05 | Üzenet/Post # 563 |
Hi Amator,
The left is a panel I covered in what I believed to be Birch veneer and the right is standard Birch ply. The Birch ply appears to contain a lot of tar (at least I assume it's tar) and does char to an extremely black color.
Dátum/Date: Hétfő, 2017-09-11, 12:22 | Üzenet/Post # 564 |
tweakie, I never thought that Birch can be lasered so dark. The Birch ply available in the local shops give brown results, stronger beam just vaporize the wood and makes deeper engraving.
Dátum/Date: Kedd, 2017-09-12, 05:39 | Üzenet/Post # 565 |
Hi Amator,
I must admit to knowing very little about wood but my experience to date has been exactly as you describe - too powerful a beam vaporizes the wood and reduces the darkness of the char. This particular sheet of Birch ply certainly behaves differently - I have 6 more tree pictures to make (as time permits) and I am assuming they will all be just as dark.
maffia1 |
Dátum/Date: Kedd, 2017-09-19, 19:48 | Üzenet/Post # 566 |
Üzenetek/Posts: 6
sziasztok! Kinai co lézerem van üvegbe vagy tükörbe szeretnék gravirozni de nem nagyon sikerül, elég csunya . valami beállítási hiba lenne vagy tul erös hozá a gép?
Az üzenetet módosította/Modified by maffia1 - Kedd, 2017-09-19, 19:58 |
Dátum/Date: Szerda, 2017-09-20, 05:50 | Üzenet/Post # 567 |
Unfortunately CO2 lasers do not engrave glass very well.
maffia1 |
Dátum/Date: Csütörtök, 2017-09-21, 17:25 | Üzenet/Post # 568 |
Üzenetek/Posts: 6
sziasztok! meg tudja valaki mondani miben befolyásolja a lencse és tükör méret a müködést? pl: ha kisebb vagy nagyobb lencsét teszek bele akkor mi változik? |
Dátum/Date: Csütörtök, 2017-09-21, 18:58 | Üzenet/Post # 569 |
maffia1, semmiben. A tükör egy nagyságrenddel nagyobb mint a nyaláb, akárcsak a lencse. Ami számít az a visszavert lézermennyiség vagyis hogy minél kevesebb energia nyelődjön el a tükörben. A lencsénél viszont az számít hogy minél többet átengedjen, pontos legyen a kiképzése, meg persze a fókusztávolsága.
maffia1 |
Dátum/Date: Csütörtök, 2017-09-21, 19:37 | Üzenet/Post # 570 |
Üzenetek/Posts: 6
Amatőr, elvileg akkor ez ugy müködik mint amikor gyerek korunkban a nyítótval megyujtottuk a papirt a napfényel? |
Dátum/Date: Péntek, 2017-09-22, 20:18 | Üzenet/Post # 571 |
maffia1, igen, a lencse feladata a nyaláb minél kisebb átmérőre fókuszálása.
Dátum/Date: Hétfő, 2017-12-04, 16:22 | Üzenet/Post # 572 |
Hello everyone! I've got an issue with my CO2 laser, that may will solve with Your help. At the whole working are I have no constant laser power. As the Y axis go positive, the upper area getting less laser power.
 On this image the red color represents the power. I'm sure it's not the warming up, if after a work I bring the Y axis down, it has power again. I have no device to measure, I would say the power loss is about 20%. What can cause this behavior?
Dátum/Date: Kedd, 2017-12-05, 07:28 | Üzenet/Post # 573 |
Hi Amator,
Usually it is incorrect mirror alignment where the beam moves position on the lens with axis movements. Try setting a very low power and place a piece of paper over the lens position. The laser will make a dot on the paper - does the position of this dot move with different axis positions ?
When measuring very small variations in laser power the dot size at the lens is important (the further away the lens from the source, the larger the dot). To take advantage of this effect beam expanders are often used within the focus lens assembly - this produces a larger dot size for the lens to focus and as a result there is better quality focus giving the effect of more power.
Hope this helps,
Dátum/Date: Kedd, 2017-12-05, 20:30 | Üzenet/Post # 574 |
tweakie, I revised the mirror adjustment, and You was totally right, it was not correct. Unfortunately the readjustment cannot fully help. For example if I try to set the first mirror, I cannot shot the same spot on the second mirror if the Y axis is up and down. I needed a bit move the second mirror sideway, what I could do after a few file on the metal holder. It seems the laser spot still moves on the third mirror as the mechanism moves, but at least it's always on the mirror's surface, not on the edge. Power checking on the whole area coming soon, I have good presentiment about it. Thanks again for Your advice!
Dátum/Date: Szerda, 2017-12-06, 07:44 | Üzenet/Post # 575 |
Hi Amator,
Mirror alignment is not always an easy task - sometimes luck plays a part
Dátum/Date: Péntek, 2017-12-08, 11:46 | Üzenet/Post # 576 |
tweakie, then I was lucky  Another question related to laser: What software can make a toolpath like this:
 This short cut comes from AxiDraw V3 video.
Dátum/Date: Péntek, 2017-12-08, 12:49 | Üzenet/Post # 577 |
Hi Amator,
That is a very interesting method of Halftone which I have never seen before now. The Axidraw software works within Inkscape and that is where the .svg image is loaded and processed. I am guessing that the processed image data is in HPGL format and the Pen Up / Pen Down / X & Y coordinates are then sent to the actual pen drawing machine controller by the Inkscape, Axidraw extension. Chances are that Axidraw have protected their extension in some way to prevent us from using their software to extract the HPGL (which can easily be converted to Gcode) and then used with a laser. However, if there is one thing I have learned in this life is that, no matter what, there is always a way. When I get a bit more time I will read-up about Axidraw and see what I can find out.
Dátum/Date: Szombat, 2017-12-09, 08:05 | Üzenet/Post # 578 |
Hi Amator,
This halftone technique is called SquiggleDraw ( https://github.com/gwygonik/SquiggleDraw ) and it is an App. which runs inside Processing ( https://processing.org/ ) the result is an .svg file.
Hope this helps,
Dátum/Date: Szombat, 2017-12-09, 12:08 | Üzenet/Post # 579 |
As an addition to the above post I have just noticed that Aspire9 can import .svg files so creating a Mach toolpath would not require Axidraw or Inkscape ( as previously thought ).
Dátum/Date: Vasárnap, 2017-12-10, 17:00 | Üzenet/Post # 580 |
tweakie,Thanks for the research! I was trying with this Processing program, I could open the sketch, but don't know how to use it. It needs programmer thinking and I'm a simple user. This beats me.
