CO2 Lasers.
Dátum/Date: Péntek, 2015-04-17, 17:49 | Üzenet/Post # 501 |
Üzenetek/Posts: 2306
tweakie, that also means that I reached the final quality with laser photo engraving, it will not be better. I can relax now
Dátum/Date: Szombat, 2015-04-18, 06:53 | Üzenet/Post # 502 |
Üzenetek/Posts: 1036
There is never time to relax my friend - there are always new techniques to learn
Dátum/Date: Szombat, 2015-04-18, 10:54 | Üzenet/Post # 503 |
tweakie, You're right aganin, I have a new idea how to decrease the spot. It would be simple to decrease the power and see what happens. I suppose it would be smaller spot, because higher power gives bigger spots. Not bigger focus spot, but bigger mark on the material. The problem is that I cannot go under 4mA because the power supply goes non-linear, gives out noises. What if I try to take back the power with PWM? Just like Your solution does:
Dátum/Date: Szombat, 2015-04-18, 11:48 | Üzenet/Post # 504 |
Hi Zoltan,
Yes indeed sir - By pulsing the laser using PWM (or similar methods) you can achieve a series of very short (uS) trigger pulses thereby enabling the tube current to be set to a much higher level for the same apparent power output (but take care not to exceed a Pulse Repetition Frequency of 20 kHz).
This is the system I have been using with my laser for some time now as it allows the laser tube to trigger reliably when requiring a very low power output. And, as you have said, it enables an extremely small spot size to be produced (although feed-rate may have to be reduced to compensate).
We will never stop learning my friend.
Dátum/Date: Szombat, 2015-04-18, 18:24 | Üzenet/Post # 505 |
Amatőr, Szia Zoltán!
Elnézést a belebeszélésért ,de érdekel a dolog. Mivel nem tudok angolul ,ezért csak a fordítóra támaszkodom. ha jól értelmezem a leírtakat arról megy a diskurzus ,hogy a Te 40W-os (Kínai?) lézered fókuszpontja nem vihető 0.3mm alá. És az olvasottakból az derül (számomra ) ki ,hogy Profi lencse és gáztöltés a megoldás, Viszont lehet javítani a helyzeten a PWM-es vezérléssel a fenti kis elektronika segítségével. Kérlek javíts ki amit rosszul értelmeztem.
Mikibá
Dátum/Date: Szombat, 2015-04-18, 19:21 | Üzenet/Post # 506 |
miki-bá, jól érted. A profi lencse iszonyú drága, ezt el is vetettem. Az ötlet az hogy kisebb teljesítményt használjak. Nagyobb teljesítmény nagyobb jelölést csinál az anyagon. A fókuszpontot nem tudom csökkenteni, de a teljesítményt talán igen. Jelenleg nem tudok 4mA alá menni (20 a max.) mert alatta instabil a tápegység, ekkor került képbe a PWM vezérlés, azzal ki tudnám próbálni mi történik kisebb teljesítményen.
Dátum/Date: Szombat, 2015-04-18, 19:28 | Üzenet/Post # 507 |
Amatőr, Köszönöm a válaszod.Sok sikert.
Dátum/Date: Szombat, 2015-04-18, 19:34 | Üzenet/Post # 508 |
tweakie, it is interesting what You say about the PWM frequency. Is there any reason to not to exceed 20kHz? I thought I will need to be minimum 10 times more narrow PWM pulses than a pulse of one pixel burned. Currently I don't know this time, and have to figure out how to measure.
Dátum/Date: Szombat, 2015-04-18, 19:35 | Üzenet/Post # 509 |
miki-bá, köszi, valahogy kipróbálom a dolgot a gyakorlatban.
Dátum/Date: Szombat, 2015-04-18, 20:09 | Üzenet/Post # 510 |
Amatőr, Sziasztok
A néztem a képet,vidit, Kivitelezés jeles,gép oldalról nézve megint jeles.Szépen dolgozik jól össze hoztad. A maróval gravírozott képedet azért nem szárnyalja túl Mennyi idő alatt sikerült befejezned? Kép méret gondolom amit megszoktunk tőled. Mekkora főkusztávú lencsét kaptál a géppel(csak kérdem, lehet már beszéltünk róla, csak kicsit furcsálom azt a 0.3mm Nekem 50 es lencsével 0.07 körüli, amit mondjuk plexibe fémen stb tudsz leellenőrizni. Fánál ne nézd, mert ott eleve nagyon hamar megkapja, üvegnél meg kirobbant az üvegből azért tűnik nagynak. Én csodálkoztam hogy co2 lézerrel hátulről gravírozod a tükröt. Próbáld meg egyszer a másik oldaláról. Amikor fókuszban van az üveg éles hangon serceg, nagyon szépen el lehet találni a fókuszt rajta. ahoz hogy ne robbantson ki akkora pontot, vizes papírral fedd le a gravírozandó felületet.Nekem a többrétegű törlőből egy réteg, de lehet bármi ami vékony és papír.(vékony fánál is csináltam már úgy,hogy ne lőjje át, ott is működik) A lényeg vékony legyen, és ázzon át teljesen(arra vigyázz ne tocsogjon.) A pwm es szabályzásról meg írtam a vidi alatt. Nekem nem jött be, de Te lehet ügyesebb leszel Üdv Zasti
Dátum/Date: Vasárnap, 2015-04-19, 05:56 | Üzenet/Post # 511 |
Hi Zoltan,
Although it has not been proven beyond doubt - general opinion is that 20kHz is the maximum frequency that can be handled by the laser PSU trigger input pin.
Dátum/Date: Vasárnap, 2015-04-19, 14:12 | Üzenet/Post # 512 |
zasti, gép oldalról nincs mivel büszkélkednem, az a kis kínai érdeme. Még most sincs minden készen, pár dolog még várat magára. A fókusz 2" elvileg, valami átlátszatlan fekete lencse. Biztosan nem profi cucc. Azért gravírozom a foncsor felől, mert ha szemből készül akkor tükröződik a kép, úgy nem tetszik. Jó volna szárazon megoldanom, azért gondoltam a PWM-re, ki kell próbálni.
Dátum/Date: Vasárnap, 2015-04-19, 14:13 | Üzenet/Post # 513 |
tweakie, thanks, that's a new info for Me.
Dátum/Date: Vasárnap, 2015-04-19, 14:29 | Üzenet/Post # 514 |
I made a short test with 0,2mm raster, with decreased power. The PSU is strange, when I turn the power down to zero and slowly increase, the indicator comes up, and I hear noise. When I reach the 4mA, suddenly the PSU becomes silent, and the indicator falls back to 3mA. Over it I can reach the 4mA again, but I'm sure it is not the same as before. Although I thought it not the best for the PSU, I tried in this noisy zone. Here is the theoretical test: And the result: It seems I can really decrease the mark spot with lower power. Now a test picture is running on the machine, I'll come back with the results.
Dátum/Date: Vasárnap, 2015-04-19, 15:45 | Üzenet/Post # 515 |
Here is a 60x60mm picture, made with 0,2mm raster:
Seems every pixel is on it's place.
The image is correct, but very dark, the marks aren't white. I have no idea what shold be the next step. If I increase the burning time the marks will be white, but probably bigger too.
Dátum/Date: Vasárnap, 2015-04-19, 15:56 | Üzenet/Post # 516 |
Hi Zoltan,
Can you send me a copy of that image and I will see what I can do with my set-up.
Dátum/Date: Vasárnap, 2015-04-19, 16:41 | Üzenet/Post # 517 |
Hi Tweakie! It is a random picture from the net. Here it is without modification:
Dátum/Date: Vasárnap, 2015-04-19, 18:01 | Üzenet/Post # 518 |
I made another test with 0,15mm raster, just to see if the spot size lets Me do it:
The picture is smooth, much better than before. I also tried vith air assist but it gives the same results Here is a comparsion with an old (0,3 raster) picture:
Maybe it's visible what is the difference. Higher resolution is not so white. In my hand the difference is significant. The new pic also looks smudgy, maybe the PSU is not stable at this power.
Dátum/Date: Hétfő, 2015-04-20, 10:32 | Üzenet/Post # 519 |
Hi Zoltan,
Your work is certainly better than my feeble attempt (ignoring the scratches on my mirror).
This was done in reverse (I lasered the black areas then painted the back of the mirror black). This enables the image (mirror) to be viewed in open daylight.
Dátum/Date: Hétfő, 2015-04-20, 13:19 | Üzenet/Post # 520 |
Just by way of a comparison, this is the same image reproduced using a smaller dot size.
