CO2 Lasers.
Dátum/Date: Péntek, 2015-02-13, 06:53 | Üzenet/Post # 481 |
Hi Zoltan,
I have found, that on my PC when it is first initialized,some LPT output pins are in the High state and some are in the Low state (this situation may change between different PC’s and different parallel port cards). As a result I choose LPT pin 16 as my laser trigger because (in my case) it always starts up in a High state. Others have used a macro or code preamble to do a M10P1 command and imaginary axis move at the start of every Gcode program – just to make sure the laser is off before any real axis movements occur.
I think in your case, placing an M10P1 after the T1 commandshould resolve the issue.
Dátum/Date: Péntek, 2015-02-13, 08:45 | Üzenet/Post # 482 |
tweakie, I always turn on the laser after Windows startup to avoid state changes on LPT pins. The ca. 1 second burning exactly starts when I hit the "Cycle start" button. Although I don't see any strange there, maybe something is wrong in gcode. I will try Your suggestion. Another interesting part is when I stop a half ready work. The lens is over the workpiece with a turned off laser. When I hit the "Goto Zero" button, the lens moves to the starting point, but during movement the laser fires. Maybe the two thing has the same root.
Dátum/Date: Kedd, 2015-02-17, 10:11 | Üzenet/Post # 483 |
Some new thing: when I remove the Sxxxx M3 command, the laser does not fire at the beginning. How can this command cause the laser switch on?
Dátum/Date: Kedd, 2015-02-17, 11:07 | Üzenet/Post # 484 |
Ahh, the mysteries of Mach3.
Do you perhaps have the spindle configured to the same pin number as your laser trigger (Output#1) ??
Dátum/Date: Szerda, 2015-02-18, 16:40 | Üzenet/Post # 485 |
tweakie, You were right, I had to disable the spindle. The default setting is to start it on M3 command, my Laser Mach profile is getting better and better I was trying out the HDD discs as mirror, and they work perfectly. Now I have spare parts if I need. I also discovered that cutting plywood can be faster if the focus point is setted to the bottom surface. I don't know the reason, but I could cut ca. 50% faster than focus on upper side. The cutting has a little angle, but not disturbing.
Dátum/Date: Szerda, 2015-02-18, 17:09 | Üzenet/Post # 486 |
Hi Zoltan,
I am pleased you found the problem.
Excellent work with the biplane
Dátum/Date: Péntek, 2015-02-20, 21:13 | Üzenet/Post # 487 |
Idézet tweakie (  ) Excellent work with the biplane Thanks Tweakie, my little son will inspect it
elektron |
Dátum/Date: Kedd, 2015-02-24, 18:07 | Üzenet/Post # 488 |
Amatőr, ezt szerinted egy fekete kartonpapírból is meg lehetne építeni, ha kivágnám egy 1Wos lézerrel ? Persze a rajzon az összeillesztéseknél egész vékony kivágások kellenének akkor. |
Dátum/Date: Kedd, 2015-02-24, 18:41 | Üzenet/Post # 489 |
elektron, nem látom akadályát. Ha tudod vágni az anyagot akkor már nyertél.
mex |
Dátum/Date: Kedd, 2015-02-24, 19:30 | Üzenet/Post # 490 |
Üzenetek/Posts: 56
elektron, el lehet pepecselni az illesztések méretének változtatásával jó ideig... Próbáld ki a dekorgumit, az infra szerintem jól viszi a fekete színűt. http://www.imgserv.com/images/2015/02/24/DrjlTeHaO.jpg
Az üzenetet módosította/Modified by mex - Kedd, 2015-02-24, 19:33 |
elektron |
Dátum/Date: Kedd, 2015-02-24, 20:07 | Üzenet/Post # 491 |
Kösz, majd most kezdek ezzel kísérletezni, időszerű a dolog. Ez a dekorgumi valami papírboltban vehető ? Vagy vegyszeresnél ?
Az üzenetet módosította/Modified by elektron - Kedd, 2015-02-24, 20:08 |
Dátum/Date: Kedd, 2015-02-24, 20:22 | Üzenet/Post # 492 |
Idézet elektron (  ) Ez a dekorgumi valami papírboltban vehető ? Így van, kb 70Ft/A4 lap. Egy kis segítség az illesztések beállításához, a mellékelt dxf-t módosítva hamar megtalálod az anyaghoz használható illesztő méretet:
Dátum/Date: Csütörtök, 2015-04-16, 17:44 | Üzenet/Post # 493 |
Hi guys!
I had some free time, so made a video about how the modified Chinese laser machine runs with a DotG code:
Dátum/Date: Csütörtök, 2015-04-16, 19:02 | Üzenet/Post # 494 |
Amatőr, Hasít a gép ! A kép minőségét Te tudnád összehasonlítani a régiekkel. Remélem szép.
Dátum/Date: Csütörtök, 2015-04-16, 19:13 | Üzenet/Post # 495 |
miki-bá, köszi! A kép minősége megegyezik a régi mechanikussal, sajnos itt sem tudok 0,3mm raszter alá menni, ekkora legkisebb képpont. Talán egy jobb lencse segítene. Itt kb. 70000 képpont készült fél óra alatt, sokkal gyorsabb mint a mechanikus módszer.
Dátum/Date: Péntek, 2015-04-17, 06:01 | Üzenet/Post # 496 |
Excellent work Zoltan - as you say the laser is a lot faster than the electro-magnet.
Dátum/Date: Péntek, 2015-04-17, 07:42 | Üzenet/Post # 497 |
tweakie, thanks! As I count it was average 48 dot/second. I found a site, where there is info about the laser spot size. It says, my 0,3mm spot is good, but the interesting part is on the bottom of the page: "-- 'D' may be increased 2 or 3 times by using a 'beam expander' -- which means spot size will be 2 or 3 times smaller BUT -- depth-of-field will be 4 or 9 times less." If the depth of field will be less is not so important for Me. Can I reach 0,1mm spot size this way?
Dátum/Date: Péntek, 2015-04-17, 11:05 | Üzenet/Post # 498 |
Hi Zoltan,
I think the professional laser machine manufacturers have demonstrated that by using a beam expander and a high quality lens you can indeed get down to a 0.1mm spot size but you would have to be very serious about doing it because of the cost of the optics involved.
When it comes to lens’s there is a world of difference between a cheap Chinese lens and those manufactured by say II-VI (and other US manufacturers) so a high quality lens is probably the first step to take.
Dátum/Date: Péntek, 2015-04-17, 15:05 | Üzenet/Post # 499 |
tweakie, it was not easy to find lens prices, many shop wants inquiry. I found some, and think that this solution stays theoretical for Me. It would be strange when a lens costs 50% of the whole machine, it's not for hobbysts.
Dátum/Date: Péntek, 2015-04-17, 15:25 | Üzenet/Post # 500 |
Hi Zoltan,
I think that’s absolutely correct – it’s only a hobby and unfortunately,we are all limited by cost.
(My GaAs and ZnSe lens’s together with the mirrors and their mounts came from Newport Corp. in the USA and cost me more than all the other laser components put together).
