CO2 Lasers.
tweakie Dátum/Date: Hétfő, 2014-12-22, 13:38 | Üzenet/Post # 401
My flow-switch is connected in series with the safety interlock circuit which is the 'WP' terminal on my laser PSU (if the flow-switch goes open-circuit the laser cannot be fired).
Amatőr Dátum/Date: Hétfő, 2014-12-22, 17:16 | Üzenet/Post # 402
On my power supply there is a firing point too, I will use it, thanks for the advice. Also I can build in a safety switch too.
What do You think the flow sensor I linked before?
tweakie Dátum/Date: Kedd, 2014-12-23, 06:38 | Üzenet/Post # 403
Hi Zoltan,
That type of flow sensor looks just fine. I assume it has a Hall effect sensor, so once you know the pulse rate (under normal coolant circulation) the timing of a 555 can be set to keep a relay closed - the contacts of which will then be connected in series with the protection circuit.
Amatőr Dátum/Date: Kedd, 2014-12-23, 17:48 | Üzenet/Post # 404
Today I tried the machine with a DotG code, it was running with a lot of area to burn. The time was more than an hour, but the temperature raised only 2,8~3°C. Now I can be sure that the pump flow is enough.
Here is the result, a bit overburned:
And for just fun I tried a piece of laminate. It's a 40mm high arms.
Csatolások/Attachments: 7106116.jpg(424.0 Kb) · 1742821.jpg(459.1 Kb)
tweakie Dátum/Date: Kedd, 2014-12-23, 18:54 | Üzenet/Post # 405
Excellent  respect
Amatőr Dátum/Date: Szerda, 2014-12-24, 14:34 | Üzenet/Post # 406
tweakie, thank You!
Merry Christmas to You all!
Csatolások/Attachments: 8901815.jpg(104.5 Kb)
zasti Dátum/Date: Vasárnap, 2014-12-28, 13:50 | Üzenet/Post # 407
Amatőr
Alakulsz rendesen. smile gratula szép munka, és a végeredmény 10/10!
Mostanába nagyon nem vagyok errefelé, de kérdezném
A triggerelést hogyan oldottad meg? Mennyi idő neked kb egy raszteres mondjuk 200x200, Levegőt sikerült megcsinálnod vágáshoz? Vektoroshoz, mit használsz stb.???Le vannak ezek írva valahol?
Mostanában csk plexis vidiket láttam tőled.
picengraver Dátum/Date: Vasárnap, 2014-12-28, 18:22 | Üzenet/Post # 408
Zoltan,
Your work is very beautiful.  Thank you for sharing.
Happy New Year,
Amatőr Dátum/Date: Hétfő, 2014-12-29, 07:53 | Üzenet/Post # 409
zasti, szia!
Köszönöm, kezd összeállni a folyamat smile
A DotG laser plugin-t használom, M11P1 és M10P1 kapcsolgat egy kijelölt pin-t. Időzítés nincs, teljes sebességgel megy a gép, amennyi időre megáll egy pont felett ahhoz igazítom a lézer teljesítményét. Ez a méret kb. 130x180 úgy egy óra, gondolom 200x200 két óra körül lehet. Levegő még kipróbálás alatt van, egy akvárium pumpa fogja tolni a levegőt a fejhez egy kis szilikon csövön.
Nálad mi a helyzet? Alakul a gép?
Amatőr Dátum/Date: Hétfő, 2014-12-29, 07:57 | Üzenet/Post # 410
John, Thank You!
I got many help here, the machine is close to work safely and as I wanted.
Happy new year to You too!
Amatőr Dátum/Date: Kedd, 2014-12-30, 20:54 | Üzenet/Post # 411
csewe, menjünk át ide!
Amatőr Dátum/Date: Szombat, 2015-01-03, 20:46 | Üzenet/Post # 412
tweakie, earlier You had a challenge to laser something into a grant of rice.
Here is my result:
It seems the CO rather cut than mark, but I hope it's recognizable smile
Csatolások/Attachments: 2889604.jpg(464.1 Kb)
miki-bá Dátum/Date: Szombat, 2015-01-03, 21:27 | Üzenet/Post # 413
Amatőr,        NAGYON KIRÁLY      !!!!
Az üzenetet módosította/Modified by miki-bá - Szombat, 2015-01-03, 21:28
Amatőr Dátum/Date: Vasárnap, 2015-01-04, 07:50 | Üzenet/Post # 414
miki-bá, köszi!
Lehetett volna szebb is, a fán sokkal jobban mutat:
Szerencsére nem kell ilyent sűrűn csinálnom biggrin
Csatolások/Attachments: 6018332.jpg(133.2 Kb)
tweakie Dátum/Date: Vasárnap, 2015-01-04, 09:11 | Üzenet/Post # 415
Excellent  ok
You are now an official member of the 'Grain of Rice club'.  biggrin
Amatőr Dátum/Date: Vasárnap, 2015-01-04, 15:09 | Üzenet/Post # 416
tweakie, thanks, I've got a lot to learn more.
mbarosevic Dátum/Date: Kedd, 2015-01-13, 09:01 | Üzenet/Post # 417
Üzenetek/Posts: 8
Hello, I am new on this forum. I have few questions if someone can help me.
I am building homemade laser 40w, working area 1000 x 650mm. It is almost done and there was few testings. I am not sadisfied with results because i don't get strait edges. Maybe it is wrong mach3 setup, but i think that is mechanical problem? I'll post later pictures of machine and test.
Question: how much drive belts must be steched? I am using 10mm T5 belt.
Regards, Marko
tweakie Dátum/Date: Kedd, 2015-01-13, 09:29 | Üzenet/Post # 418
Hi Marko, welcome to the forum.
We all like pictures so some pics of your machine and set-up would be great also post up a picture of the problem as this will give us a better idea for the 'non-straight edge' solution.
I don't actually use drive belts so perhaps someone else here can advise on the correct tension to set.
mbarosevic Dátum/Date: Szerda, 2015-01-14, 11:17 | Üzenet/Post # 419
Üzenetek/Posts: 8
There are pictures of my work:
http://s67.photobucket.com/user/marcobc/slideshow/laser
Amatőr Dátum/Date: Szerda, 2015-01-14, 12:23 | Üzenet/Post # 420
Marko, welcome to the forum!
I had similar problem with the laser, it was an unfixed mirror, could move because of the machine's vibration.
I think it's not software issue, rather mechanical.
Copyright HobbyCnCArt © 2021
