Dave Dátum/Date: Péntek, 2012-10-12, 13:54 | Üzenet/Post # 141
Probably not, since I have trouble seeing a rice grain w/o my glasses.
JJWMACHINECO Dátum/Date: Péntek, 2012-10-12, 15:46 | Üzenet/Post # 142
OK, here it is Dave. A laser engraving of a rice laser engraving. ok
Csatolások/Attachments: 8850032.jpg(147.0 Kb)
Az üzenetet módosította/Modified by JJWMACHINECO - Péntek, 2012-10-12, 15:49
picengraver Dátum/Date: Péntek, 2012-10-12, 18:30 | Üzenet/Post # 143
Jeff,
Outstanding job.
JJWMACHINECO Dátum/Date: Péntek, 2012-10-12, 18:50 | Üzenet/Post # 144
John,
Thank you and I do have to say outstanding job to you for creating this excellent, easy to use engraving software.
Amatőr Dátum/Date: Szombat, 2012-10-13, 08:30 | Üzenet/Post # 145
Hi men! Nice works, You know how to make impressive job, grats!
Dave Dátum/Date: Szombat, 2012-10-13, 13:30 | Üzenet/Post # 146
Another day, another picture. 5x7", 50IPM on poplar, 90% power.
Csatolások/Attachments: 3725157.jpg(165.0 Kb)
JJWMACHINECO Dátum/Date: Szombat, 2012-10-13, 20:12 | Üzenet/Post # 147
Very nice engraving Dave. It looks like you have your process down and the detail is really coming out now. Could you have run that at 100%/60IPM? Just curious.
The picture editing tools John added really helps considerably too, don't you agree?
Az üzenetet módosította/Modified by JJWMACHINECO - Szombat, 2012-10-13, 20:14
Dave Dátum/Date: Szombat, 2012-10-13, 21:27 | Üzenet/Post # 148
Hi Jeff,
I'm thinking I could have done 60ipm at 100%. Haven't tried that on birch or poplar though, so I'm just guessing. I just ran a test at 60ipm at 40% on luan, came out sort of ok but the strong grain wrecks the final product. On poplar, the images almost look 3D-ish. Still looking for wood that burns easily (reddish or tannish tint) but without the grain of the luan I have. Another road-trip is in order wink
And yes, I really like the stuff John's added!
JJWMACHINECO Dátum/Date: Csütörtök, 2012-10-18, 23:17 | Üzenet/Post # 149
Another Pretty Kitty engraving done today with John's latest version.
Csatolások/Attachments: 9124415.jpg(87.8 Kb)
tweakie Dátum/Date: Péntek, 2012-10-19, 06:41 | Üzenet/Post # 150
Hey Jeff, they just keep getting better and better.
Absolutely excellent work. ok
Dave Dátum/Date: Péntek, 2012-10-19, 12:56 | Üzenet/Post # 151
Looks great Jeff!
JJWMACHINECO Dátum/Date: Szombat, 2012-10-20, 12:11 | Üzenet/Post # 152
Thanks guys.
I did a test yesterday that compared the Mouse Pad image I engraved and posted on the Vectric forum. John's program definitely gives allot more detail then PVC. I did some tweaking with my depths and went to -.0038" from where my encoder jumped to 5V and zeroed Z there and set the total depth at Z-.0255" and used .0035" retract. This put me .0003" to a darker shade at the low end and .0002" darker shade at the high end. It was .0002" movement at the high end from jumping back to 0V with the encoder. I ran it at 50IPM and the overall image came out darker. I believe at this setting I can squeeze another 5IPM and run at 55IPM. I will try that later today. I also purchased some Poplar to try out.
Forgot to mention that I set gamma at 2 and sharpen at 5.
Csatolások/Attachments: 3290905.jpg(120.2 Kb) · 9723722.jpg(178.0 Kb)
Az üzenetet módosította/Modified by JJWMACHINECO - Szombat, 2012-10-20, 13:06
miki-bá Dátum/Date: Szombat, 2012-10-20, 12:24 | Üzenet/Post # 153
JJWMACHINECO,
hands hands hands hello
JJWMACHINECO Dátum/Date: Szombat, 2012-10-20, 14:30 | Üzenet/Post # 154
This picture I never could get it to come out right with PVC, but only took 1 try with PicEngrave Pro Laser Edition. I ran this one at 55IPM and probably could have at 60IMP. Now If I could just get a picture of the Mouse Pad girl riding this Harley. I'm not talking hands free either. smok
Csatolások/Attachments: 9954840.jpg(143.8 Kb)
Az üzenetet módosította/Modified by JJWMACHINECO - Szombat, 2012-10-20, 14:31
Dave Dátum/Date: Hétfő, 2012-10-22, 16:44 | Üzenet/Post # 155
Looks good Jeff!
How large are the images that you burned? I'm having some difficulty with smaller sizes (5x7") getting all the detail that's in the image. Might be due to mach's cv stuff smoothing out the tool path.
JJWMACHINECO Dátum/Date: Hétfő, 2012-10-22, 18:15 | Üzenet/Post # 156
Hi Dave,
The two babe pictures are 7.75" X 9.75" and the Harley is 7.75" X 5.25". I tried the Poplar and did not have very good results at all with it. It just does not burn as easy as the Birch ply. It may do better if I had more power like your laser, or did you figure out a trick on engraving with it?
tweakie Dátum/Date: Kedd, 2012-10-23, 06:31 | Üzenet/Post # 157
Just a thought Dave...
Are you getting your focus to a really tight dot ??
JJWMACHINECO Dátum/Date: Kedd, 2012-10-23, 12:50 | Üzenet/Post # 158
Anyone up for a wet T-shirt contest of laser engraving? The best way I have found to focus the lens to get the smallest dot is to use a piece of black anodized aluminum. Throttle it up some first. The idle glow is hard to tell.
Csatolások/Attachments: 9345337.jpg(142.7 Kb)
Dave Dátum/Date: Kedd, 2012-10-23, 12:50 | Üzenet/Post # 159
Hi Tweakie,
Yes, I may have been a bit off on the focus. Did some testing yesterday by burning a line on a inclined piece of wood, noting where the line is narrowest and using that point to establish the distance from the laser to the target. Prior to that I had been using blowing some smoke in the beam to see where the focal point is. There wasn't much difference between the two. It might be that some of the pictures I've tried just aren't very good for this, or maybe it's mach's CV stuff. I have more game playing to do I think.
Amatőr Dátum/Date: Kedd, 2012-10-23, 17:14 | Üzenet/Post # 160
Jeff! Nice burnings indeed, congratulations!
