tweakie Dátum/Date: Csütörtök, 2013-06-20, 07:54 | Üzenet/Post # 821
As always, very nice work Pablo. ok
Pabló Dátum/Date: Csütörtök, 2013-06-20, 09:05 | Üzenet/Post # 822
tweakie
Thank you!
fefenin Dátum/Date: Csütörtök, 2013-06-20, 09:30 | Üzenet/Post # 823
Üzenetek/Posts: 34
very nice work!
zasti Dátum/Date: Csütörtök, 2013-06-20, 21:10 | Üzenet/Post # 824
Pabló
Király munka. respect
ez azért kicsit jobb mint az 1w smile
Az Óra-mechanika elfogyott  crazy
Pabló Dátum/Date: Csütörtök, 2013-06-20, 21:43 | Üzenet/Post # 825
Idézet (zasti)
Király munka. respectez azért kicsit jobb mint az 1w smile
Köszi!
Idézet (zasti)
Még van, de közbe kell más is, nehogy már minden ketyegjen! biggrin
JJWMACHINECO Dátum/Date: Péntek, 2013-06-21, 16:16 | Üzenet/Post # 826
Nice job Pablo!
Blonds are more fun! To laser engrave anyway. biggrin yes
Csatolások/Attachments: 6312787.jpg(115.5 Kb)
csewe Dátum/Date: Péntek, 2013-06-21, 16:53 | Üzenet/Post # 827
Hi Jeff.
Again, the usual high quality.
Congratulations.
Zoli.
JJWMACHINECO Dátum/Date: Péntek, 2013-06-21, 17:04 | Üzenet/Post # 828
Thanks Zoli,
I know I'm getting some issues going on with the shading because I have not cut any new Birch Plywood yet. I'm starting to use the backs of my other engraved pieces now. It's probably not Birch on the back so there not coming out as good as before, but they are exceptable. It looks like the grains are effecting the shading to much.
Pabló Dátum/Date: Péntek, 2013-06-21, 17:40 | Üzenet/Post # 829
JJWMACHINECO
Thank you Jeff!
the dog is not fair! biggrin
nice work! up
Pabló
JJWMACHINECO Dátum/Date: Szombat, 2013-06-22, 20:08 | Üzenet/Post # 830
Thanks Pablo.
I wonder if badpip2010 got a large driver order from this company.
It sure looks like analog modulation laser diode engraving to me. I wonder where they got that idea from? rolleyes
Pabló Dátum/Date: Szombat, 2013-06-22, 21:34 | Üzenet/Post # 831
JJWMACHINECO
skin?
1Watt 808nm Laser liked this also
So I thought about it, then I should try to 445nm is biggrin
Pabló
Doug Dátum/Date: Hétfő, 2013-06-24, 13:05 | Üzenet/Post # 832
Üzenetek/Posts: 47
Jeff posted this link earlier http://www.photonlexicon.com/forums....oup-Buy on the FlexMod P3 driver.  Seller in now taking preorders.
Pabló Dátum/Date: Hétfő, 2013-06-24, 19:38 | Üzenet/Post # 833
Again, for an hour, now it's a hit.   biggrin
and the first appreciable feed variable picture.
it might be even nicer  biggrin
size 60×80mm  15minute
JJWMACHINECO Dátum/Date: Hétfő, 2013-06-24, 21:46 | Üzenet/Post # 834
Very nice Pablo,
Did you use variable feedrate on the mirror also?
fefenin Dátum/Date: Hétfő, 2013-06-24, 21:57 | Üzenet/Post # 835
Üzenetek/Posts: 34
i've got news from badip2010 ebay account , my item is marked as sent today...
sad cause i also preorder a flexmod just before i received the email from badip2010.
i guess it will be usefull for some other projects!!
i hop Doug as the same news from ebay!
thank's for everyone that helped on this case.
Az üzenetet módosította/Modified by fefenin - Hétfő, 2013-06-24, 21:57
Pabló Dátum/Date: Kedd, 2013-06-25, 20:02 | Üzenet/Post # 836
JJWMACHINECO
I think it would be a good mirror of changing feed - See more at: http://www.fordító.net/magyar-....O.dpufI think it would be a good mirror of changing feed
they mirror because I do not think it would be shades
what kind of paint to achieve a nice mirror image archaic character?
There are special paints it?
Thanks: Pabló
Hozzáadva (2013-06-25, 20:02)
it happened today:
picengraver Dátum/Date: Szerda, 2013-07-17, 01:16 | Üzenet/Post # 837
Pablo,
Very nice work, but it is odd to see a clock with the numbers reversed to what I am used to seeing. smile
Muk Dátum/Date: Szerda, 2013-07-17, 15:23 | Üzenet/Post # 838
Üzenetek/Posts: 61
Question for you Diode guru's, can a higher powered diode affect glass at all?
Friend of mine was proposing a 'mobile rig' for etching on peoples glass windows and I said they'd have to pull the windows clean out to get them worked on...but we talked about Diodes would allow a mobile rig but not sure if they could make a dent or not.
picengraver Dátum/Date: Szerda, 2013-07-17, 16:11 | Üzenet/Post # 839
Rob,
I etched a paper tape mask on some drinking glasses for acid etching, and the glass was untouched by the laser at 1.6 amps of current.
If you can use a mask, then you might could use some glass etching cream for the actual etching.  The etchant I have is Armour Etch brand.
Az üzenetet módosította/Modified by picengraver - Szerda, 2013-07-17, 16:14
Pabló Dátum/Date: Szerda, 2013-07-17, 22:26 | Üzenet/Post # 840
picengraver
Thank you John!
Now this is cool! Now this is cool! biggrin
many people like to go to the Ballan hours.
eventually read only ICSI unusual!
might not have to pay my awful.
Pabló
