JJWMACHINECO Dátum/Date: Vasárnap, 2013-05-05, 13:48 | Üzenet/Post # 661
John,
when you posted this picture before, it made me do some thinking and I found this version of it and laser engraved on a mirror just for you.  biggrin
Csatolások/Attachments: 2001807.jpg(122.6 Kb)
picengraver Dátum/Date: Vasárnap, 2013-05-05, 15:47 | Üzenet/Post # 662
Idézet (JJWMACHINECO)
John,when you posted this picture before, it made me do some thinking and I found this version of it and laser engraved on a mirror just for you. biggrin
I like!  ok
Will add to Gallery.
Hozzáadva (2013-05-05, 15:47)
Idézet (csewe)
Hi guys.A new creation.
Congratulation Zoli.
You will soon be good competition for our friend Jeff.  You also have his eye for works of art. yes
Pabló Dátum/Date: Vasárnap, 2013-05-05, 17:51 | Üzenet/Post # 663
JJWMACHINECO,
Jeff, respect
what about size working time, feed rate etc?
Az üzenetet módosította/Modified by Pabló - Vasárnap, 2013-05-05, 19:02
JJWMACHINECO Dátum/Date: Vasárnap, 2013-05-05, 19:54 | Üzenet/Post # 664
Did someone say something about competition? shades Did this with Version 129  wink
Thanks Pablo,
A kép mérete 280mm x 194mm. Régebben változtatható lézer teljesítmény (analóg moduláció) minimális és maximális 2V 5V a lézer meghajtó. Ez minimum Z mélysége - 0,23 mm-es és a maximális Z mélysége - 0,65 mm. Én is egy 0,18 mm-es léptetést és futott 965mm egy perc előtolást, és volt 5 óra 43 perc. Én John PicEngrave Pro 4 Laser Edition hozza létre a gcode.
Sorry Pablo, here it is again
It was Zoli that had a hard time understanding me in english.  facepalm
The image size is  280mm X 194mm. I used variable laser power (analog Modulation) with minimum 2V and maximum 5V to the laser driver. That's minimum Z depth of -.23mm and maximum Z depth of -.65mm. I used a .18mm stepover and ran at  965mm a minute feedrate and it took 5 hours 43 minutes. I used John's PicEngrave Pro 4 Laser Edition to generate the gcode.
The depth thing is because I use an absolute shaft encoder, with timing belt drive from my Z axis. It has 10-bit analog voltage output to vary the lasers power. John's program has an option to set the minimum and maximum depths and that gives me the power range I needed to burn the mirror properly.
Csatolások/Attachments: 2287235.jpg(133.4 Kb)
Az üzenetet módosította/Modified by JJWMACHINECO - Vasárnap, 2013-05-05, 22:10
Pabló Dátum/Date: Vasárnap, 2013-05-05, 21:56 | Üzenet/Post # 665
JJWMACHINECO
Hey Jeff!
Akkor én is inkább magyarul írom, ha nem gond!
Köszi a sok infót!
Ezt a mélység dolgot nem értem teljesen!
De nagyon szép sebességet értél el, biztosan jóval erősebb a ti laseretek!
Akár 1W, akár több Wattos is!
Ezt a progit ( PicEngrave Pro 4) én is néztem, biztosan nagyon jó progi!
Én DotG-t használom! De biztosan van még sok jó program!
Pabló
picengraver Dátum/Date: Vasárnap, 2013-05-05, 22:44 | Üzenet/Post # 666
Well I see the "Old Master" still has a trick or two up his sleeve.  I should've known he's not ready to retire yet. king
Hozzáadva (2013-05-05, 22:44)
Pabló
I tried to send you an email, but it came back to me marked "over quota."
Please reply so I can get your correct email address.
Thank you,
John Champlain
Pabló Dátum/Date: Hétfő, 2013-05-06, 13:46 | Üzenet/Post # 667
picengraver
Email: csonkalaszlo29@gmail.com
           pablo83@citromail.hu
Pabló
csewe Dátum/Date: Hétfő, 2013-05-06, 17:02 | Üzenet/Post # 668
Hi Jeff.
Such a good mirror engraving, we have not seen.
__________________________________________
I can not compete, because you still need to use paint to burn image.
The milling machine was too slow, the G-ray, but has a maximum 600mm/perc the feedrate.
I made these today.
Zoli.
csewe Dátum/Date: Hétfő, 2013-05-06, 17:39 | Üzenet/Post # 669
darker: 107.6*105mm 80-600mm/min 3.75hour
Brighter:107.6*105mm 120-600mm/min 3.5hour
Az üzenetet módosította/Modified by csewe - Hétfő, 2013-05-06, 17:40
Pabló Dátum/Date: Hétfő, 2013-05-06, 20:31 | Üzenet/Post # 670
Hi!
Who can help me?
Which lens would be the right one for my 3W diode?
3W 808nm
Pabló
picengraver Dátum/Date: Hétfő, 2013-05-06, 21:52 | Üzenet/Post # 671
Idézet (Pabló)
Which lens would be the right one for my 3W diode?3W 808nm
Pablo,
I do not have an 808 diode, but a lot of good information can be found here:
http://laserpointerforums.com/
Regards,
JJWMACHINECO Dátum/Date: Kedd, 2013-05-07, 00:22 | Üzenet/Post # 672
Thanks Zoli. The detail is coming out allot better on your engravings.
Pablo, contact this company. They may have a lens you need for your 3W 808nm laser. http://www.kalecnc.com/index.php/front/productDetails/27/18
csewe Dátum/Date: Kedd, 2013-05-07, 17:48 | Üzenet/Post # 673
Hi guys.
I made this today.
135*135mm line spacing 0.2mm 80-600mm/min feedrate 8hour 20min.
picengraver Dátum/Date: Kedd, 2013-05-07, 19:06 | Üzenet/Post # 674
Zoli,
Very impressive.  You have made very good progress the past few weeks.  Congratulations on your accomplishments.
JJWMACHINECO Dátum/Date: Kedd, 2013-05-07, 19:30 | Üzenet/Post # 675
Zoli,
you sure have come a long way. There coming out better and better every time.  respect
You got me beat for the longest laser engraving time competition. up
Pabló Dátum/Date: Kedd, 2013-05-07, 19:52 | Üzenet/Post # 676
Thank you everyone for your help
I found on ebay is correct lens
Now I just need to find a man who can help purchasing
there has never bought
Pabló
Hozzáadva (2013-05-07, 19:52)
csewe
Alakul ez szépen! respect
picengraver Dátum/Date: Kedd, 2013-05-07, 21:44 | Üzenet/Post # 677
Playing around a little today while tuning in my diode with the 3 element lens.
Dried pinto bean with the letter 'J' .025 inches / .635 mm high.
Csatolások/Attachments: 8077451.jpg(153.4 Kb)
JJWMACHINECO Dátum/Date: Kedd, 2013-05-07, 21:49 | Üzenet/Post # 678
Nice going John!
Now you have to try that on a grain of rice.  biggrin
Pabló Dátum/Date: Kedd, 2013-05-07, 22:07 | Üzenet/Post # 679
picengraver
John, Really cool!
I've broken my head
what weapon might carry the follow!
You are great !
Pabló
tweakie Dátum/Date: Szerda, 2013-05-08, 08:07 | Üzenet/Post # 680
Truly excellent work Zoli, looks like you have got the better of the challenge now. ok
Very fine work with the bean John. biggrin
