csewe |
Dátum/Date: Szerda, 2013-05-01, 16:08 | Üzenet/Post # 641 |
Hi Jeff.
Again, nice things-made.
Is that it? There is a coating on the tree?
Zoli. |
JJWMACHINECO |
Dátum/Date: Szerda, 2013-05-01, 17:06 | Üzenet/Post # 642 |
Thanks Zoli,
I lightly coated the wood with white wash stain.
csewe |
Dátum/Date: Szerda, 2013-05-01, 17:26 | Üzenet/Post # 643 |
Jeff.
Please write down other words, because I can not understand what you did with the tree.
Zoli. |
JJWMACHINECO |
Dátum/Date: Szerda, 2013-05-01, 17:32 | Üzenet/Post # 644 |
Sorry Zoli,
Régebben Minwax fehér mosás pácolás foltot. Használt vékony rétegben a nyír rétegelt lemez.
Az üzenetet módosította/Modified by JJWMACHINECO - Szerda, 2013-05-01, 17:42 |
csewe |
Dátum/Date: Csütörtök, 2013-05-02, 19:54 | Üzenet/Post # 645 |
Thanks Jeff, I get it.
Today I made a G-ray an image. At the bottom of the picture is a creep because it was too big the feed rate.
JJWMACHINECO |
Dátum/Date: Csütörtök, 2013-05-02, 21:40 | Üzenet/Post # 646 |
Nice job Zoli,
Looks like your on the right track to laser engraving success. I'm glad to see your getting everything worked out with your laser and G-ray program too.
picengraver |
Dátum/Date: Péntek, 2013-05-03, 11:05 | Üzenet/Post # 647 |
Zoli, Very nice.
I hope to see a lot more of your work soon.
Regards, John
Pabló |
Dátum/Date: Péntek, 2013-05-03, 21:33 | Üzenet/Post # 648 |
Hey!
I would like to inquire! Someone of you have been trying to engrave the mirror? You how much power and wavelength diode are you using? Or maybe someone like to test me?
Pabló
Az üzenetet módosította/Modified by Pabló - Péntek, 2013-05-03, 21:34 |
JJWMACHINECO |
Dátum/Date: Péntek, 2013-05-03, 22:05 | Üzenet/Post # 649 |
Hi Pablo,
If you look at my post where I have done mirrors, it will give you this information. Post #358, 361, 369, 375, 377, 385, 386 & 526.
Mine is a 1W 445nm with a 3 element glass lens.
John has done some also.
Az üzenetet módosította/Modified by JJWMACHINECO - Péntek, 2013-05-03, 22:26 |
picengraver |
Dátum/Date: Péntek, 2013-05-03, 22:10 | Üzenet/Post # 650 |
Greetings Pabló, For my mirrors, I engrave with my 445 diode at 1.6 amps of current. Some mirrors engrave with more difficulty, so the feed rate must be reduced some. I usually use about 30ipm / 762mm/m.
Hope this helps you, John
(mm feed rate corrected)
Az üzenetet módosította/Modified by picengraver - Szombat, 2013-05-04, 00:11 |
Pabló |
Dátum/Date: Péntek, 2013-05-03, 23:02 | Üzenet/Post # 651 |
JJWMACHINECO,
Great you are! In other words, you are great! And it fits you ask me if it is no secret! After that the rest of the headlamp as távolítjátok? Or is your perfect diode burn down? Or you can do it too high feed! milliméter/min how can ye feed?
PablóHozzáadva (2013-05-03, 23:02) --------------------------------------------- So I was the first sub-mirror 3W
I'm still not totally satisfied feed 270milliméter/min
Az üzenetet módosította/Modified by Pabló - Péntek, 2013-05-03, 22:43 |
JJWMACHINECO |
Dátum/Date: Péntek, 2013-05-03, 23:02 | Üzenet/Post # 652 |
Köszönet Pablo és nagyon jó munkát!
Nem vagyok egészen biztos benne, mit kér tőlem. Van információ a hozzászólás, de lehet, hogy nem érti azokat sem.
Az üzenetet módosította/Modified by JJWMACHINECO - Péntek, 2013-05-03, 23:05 |
picengraver |
Dátum/Date: Szombat, 2013-05-04, 00:09 | Üzenet/Post # 653 |
Pabló
That is a very good work of mirror art. Please write what laser you are using.
csewe |
Dátum/Date: Szombat, 2013-05-04, 05:35 | Üzenet/Post # 654 |
Hi guys.
Thank you.
------------------------------------------------------------ Pablo asks. Reflecting layer of 100% of the laser burn down? If you do not burned completely, what can be done? |
picengraver |
Dátum/Date: Szombat, 2013-05-04, 11:40 | Üzenet/Post # 655 |
Pablo, Yes, 100% of the reflecting layer is burned down. Light will pass through the mirror where it is burned if the power is enough.
Sometimes I will run a file two times to make sure that I get a better burn through.
JJWMACHINECO |
Dátum/Date: Szombat, 2013-05-04, 11:50 | Üzenet/Post # 656 |
John,
you must be using TTL and a dithered image to engrave your mirrors. When I'm using analog and make a second pass, it destroys the image.
Pabló |
Dátum/Date: Szombat, 2013-05-04, 17:56 | Üzenet/Post # 657 |
Thank you everyone! Maybe then I realize the little tricks!
Pabló
Pablo83.weebly.com |
csewe |
Dátum/Date: Szombat, 2013-05-04, 18:23 | Üzenet/Post # 658 |
Hi guys.
A new creation.
A little striped. I cleansed the lens and fixed incorrectly. But it is possible that a small focal point.
Zoli |
JJWMACHINECO |
Dátum/Date: Vasárnap, 2013-05-05, 02:02 | Üzenet/Post # 659 |
Nice Job Zoli,
Practice makes perfect!
Dátum/Date: Vasárnap, 2013-05-05, 07:16 | Üzenet/Post # 660 |
Excellent work Zoli, they just keep getting better and better
