picengraver Dátum/Date: Péntek, 2012-12-28, 23:41 | Üzenet/Post # 261
I'm starting to get my LD machine finally tuned in. Now I need to replenish my wood supply. These two were burned into cheap grade plywood - maple surface I think. They are too dark, but I'm pleased with the detail. My LD is set for .275 amps minimum and 1.2 amps maximum. More seems better, so I will try to up it to 1.4 amps max tomorrow to see if image contrast will improve.
Happy New Year All,
John Champlain
www.picengrave.com
Csatolások/Attachments: 5297116.jpg(63.4 Kb) · 0587275.jpg(123.4 Kb)
JJWMACHINECO Dátum/Date: Szombat, 2012-12-29, 01:04 | Üzenet/Post # 262
Those look excellent John. Looks like your getting everything worked out just right. thumb
picengraver Dátum/Date: Szombat, 2012-12-29, 03:59 | Üzenet/Post # 263
Thanks Jeff,
I have the DAC set so it outputs about .9 V at C0.0 and 5.0 V at C-0.0255". This gives me the full 256 bits of resolution to the analog controller and allows me to set C0 where the wood just starts to burn at feed rate. I can then adjust the controller to a min and max diode current. I'm still fine tuning this step. Previously I had been trying to reduce the max diode current to match the wood's burning characteristics. While in theory this sounded right, it seems to give less contrast to images.
I have also done some work on my machine and have it now burning at about 45 IPM. This has helped also, as it not only reduces image run time, it also seems to help even out the burn.
Dave Dátum/Date: Szombat, 2012-12-29, 04:28 | Üzenet/Post # 264
Looks good John and Jeff! Hope to have mine working again soon. Got most of the problem out of the Y axis and have parts on the way to fix the X axis.
picengraver Dátum/Date: Vasárnap, 2012-12-30, 17:46 | Üzenet/Post # 265
Hey Dave,
Lets's go. Git er smokin' (pun intended) smile :) smile
Az üzenetet módosította/Modified by picengraver - Vasárnap, 2012-12-30, 17:46
JJWMACHINECO Dátum/Date: Vasárnap, 2012-12-30, 21:46 | Üzenet/Post # 266
John,
How about we retire Drew as our beach babe? laugh
Csatolások/Attachments: 7296827.jpg(137.9 Kb)
picengraver Dátum/Date: Hétfő, 2012-12-31, 01:12 | Üzenet/Post # 267
OK, wife's beginning to suspect I have a girlfriend anyway biggrin
Great image - you've really raised the standard higher with your latest. Details?
Csatolások/Attachments: 9903054.jpg(147.6 Kb)
JJWMACHINECO Dátum/Date: Hétfő, 2012-12-31, 02:43 | Üzenet/Post # 268
Thanks John,
Same settings and the same great software. thumb
YouTube
Az üzenetet módosította/Modified by JJWMACHINECO - Hétfő, 2012-12-31, 18:56
picengraver Dátum/Date: Hétfő, 2012-12-31, 04:22 | Üzenet/Post # 269
Jeff,
Great video. Thanks much for the plug.
tweakie Dátum/Date: Hétfő, 2012-12-31, 08:38 | Üzenet/Post # 270
Excellent work guys. cool
JJWMACHINECO Dátum/Date: Hétfő, 2012-12-31, 13:27 | Üzenet/Post # 271
Thanks Tweakie.
(picengraver)
Jeff,
Great video.
I know that is not true. My video skills are not the greatest as you can see by the shaking. It has not gone public yet except the link here and I plan on doing some editing today to clean it up.
picengraver Dátum/Date: Hétfő, 2012-12-31, 22:20 | Üzenet/Post # 272
Today's effort.
Csatolások/Attachments: 0607608.jpg(201.6 Kb)
JJWMACHINECO Dátum/Date: Kedd, 2013-01-01, 01:07 | Üzenet/Post # 273
John,
Did Santa bring you some new CNC equipment? You have exceeded my capabilities with that one as it looks so realistic. respect Please give us some details of your settings and what kind of material or wood you engraved that on.
KisKZ Dátum/Date: Kedd, 2013-01-01, 01:08 | Üzenet/Post # 274
Happy new year my Friends!
Béni Dátum/Date: Kedd, 2013-01-01, 01:21 | Üzenet/Post # 275
picengraver, this is very, very dangerous ... but beautiful smile
JJWMACHINECO Dátum/Date: Kedd, 2013-01-01, 02:59 | Üzenet/Post # 276
Happy New Year everyone.
Dave Dátum/Date: Kedd, 2013-01-01, 04:09 | Üzenet/Post # 277
Happy new year to all!!!
John, that came out really good!
picengraver Dátum/Date: Kedd, 2013-01-01, 14:05 | Üzenet/Post # 278
(JJWMACHINECO)
Did Santa bring you some new CNC equipment? You have exceeded my capabilities with that one as it looks so realistic. Please give us some details of your settings and what kind of material or wood you engraved that on.
Jeff,
Quoting George Washington, "Father, I can not tell a lie; ..." The leopard image had a little help from my PaperPort scanning software, and from contrast with the forum's black background smile . Below is the actual image as scanned.
Image size is 6 x 4 inches. I used a resolution of .008 inch. LD current: max 1.4 amps - min .35 amps, with full 256 bit resolution. Wood is a piece of especially clear grained, cheap plywood from Lowe's - supposed to be birch, but who knows? It doesn't burn as easy as baltic birch, so I had to slow feed rate down from 45 ipm to 30 ipm. Took about 1.5 hours.
Csatolások/Attachments: 1784387.jpg(185.9 Kb)
tweakie Dátum/Date: Kedd, 2013-01-01, 14:17 | Üzenet/Post # 279
Excellent work John.
I agree with Barney Rubble on this one, not only dangerous, it's "scary" biggrin
picengraver Dátum/Date: Kedd, 2013-01-01, 15:09 | Üzenet/Post # 280
Tweakie, Beni, Dave, and Jeff,
Thank you. My wife caught me searching for a pinup to compete with Jeff, and guietly suggested I would do better with animals. Perhaps she was right smile
I'm not sure how far I can safely push my laser diode, but I would like to see if I can get a little more contrast without slowing down the feed rate. If I blow the LD, which I don't really want to do, at least it will give me an excuse to try one of the newer, more powerful, 445's.
