DotG software questions, answers in English
Dátum/Date: Szerda, 2011-12-14, 10:49 | Üzenet/Post # 1 |
Anything about DotG software in English |
nervino666 |
Dátum/Date: Péntek, 2013-11-22, 08:23 | Üzenet/Post # 101 |
Üzenetek/Posts: 3
Here's is the file with the correct URL. Visit our website: www.dotg.weeby.com
Az üzenetet módosította/Modified by nervino666 - Péntek, 2013-11-22, 08:24 |
Dátum/Date: Péntek, 2013-11-22, 09:23 | Üzenet/Post # 102 |
nervino666, http://dotg.weebly.com/download.html
Dátum/Date: Vasárnap, 2014-01-26, 11:47 | Üzenet/Post # 103 |
Just a scrap piece of steel plate but this image was produced using the electro-etching process discussed in more detail in this thread http://hobbycncart.com/forum/46-241-1 There was no Z axis movement and the electrode remained in contact with the work whilst the current was switched on/off to produce the ‘dots’
Dátum/Date: Vasárnap, 2014-01-26, 13:39 | Üzenet/Post # 104 |
tweakie, You improve the electro-ething to a new level!
Dátum/Date: Vasárnap, 2014-01-26, 14:23 | Üzenet/Post # 105 |
Thanks Amator, I think the work is improving all the time but I think there is still a long way to go before it could be considered good enough to match other processes. As time permits I will keep experimenting and perhaps discover something I have overlooked.
picengraver |
Dátum/Date: Kedd, 2014-01-28, 03:43 | Üzenet/Post # 106 |
Tweakie, Well done, Sir. You continue to amaze. John
Dátum/Date: Szombat, 2017-12-16, 20:23 | Üzenet/Post # 107 |
Hi Guys!
I've lost my DotG postprocessor for Mach3 using M10/M11 commands. Does anyone have it? I found one but it finish the code with turned ON laser.
Dátum/Date: Vasárnap, 2017-12-17, 06:57 | Üzenet/Post # 108 |
Hi Amator,
It is a long while since we discussed this…
DotG creates the ‘dot’ when the axis is stationery but the M10Px/M11Px commands only works at the time of axis (any axis) movement so I used a phantom B axis to fool Mach3. You need to set-up the B axis within Mach3 and depending on your settings (Acceleration, Velocity and Steps per Unit) you can control the length of time the laser ‘dot’ is fired.
My initial post processor is attached (there was another but it may take some finding).
Hope this helps.
Dátum/Date: Vasárnap, 2017-12-17, 12:48 | Üzenet/Post # 109 |
Just a note for others that follow...
You must be using Mach3 revision R3.043.056. (or later) for the M11Px / M10Px commands to work correctly.
Dátum/Date: Vasárnap, 2017-12-17, 20:02 | Üzenet/Post # 110 |
Tweakie, thanks, that helps. In Your pp in {moving} part the first command is M11P1 what turns the laser ON, then comes the M10P1 with OFF. I think it's normal. Don't You think that in my pp the M10/11 commands are inverted? Thats why at the end the laser remains ON.
Dátum/Date: Hétfő, 2017-12-18, 06:38 | Üzenet/Post # 111 |
Idézet Don't You think that in my pp the M10/11 commands are inverted? Thats why at the end the laser remains ON. That could be the case, perhaps invert the commands and see what happens ?
Dátum/Date: Hétfő, 2017-12-18, 18:04 | Üzenet/Post # 112 |
Tweakie, I changed the commands and the laser drawn little lines instead of dots. So I changed back and added an extra turn OFF at the end. Now it works as it should.
Dátum/Date: Hétfő, 2017-12-18, 18:20 | Üzenet/Post # 113 |
0,3mm raster test shots on a mirror's back side:
Dátum/Date: Kedd, 2017-12-19, 07:30 | Üzenet/Post # 114 |
Excellent
Did you add the M10P1 after {pgmend ?
Dátum/Date: Kedd, 2017-12-19, 12:43 | Üzenet/Post # 115 |
One at the end of {moving} section, and one at the {pgmend} just for sure.
Plus I had a work with it and it seems the whole work area has the same laser power.
Dátum/Date: Kedd, 2017-12-19, 13:36 | Üzenet/Post # 116 |
Idézet One at the end of {moving} section, and one at the {pgmend} just for sure. In the UK that's what we call 'belt and braces' I am pleased that it is all working out OK, keep up the good work my friend.
Dátum/Date: Csütörtök, 2017-12-21, 14:16 | Üzenet/Post # 117 |
Many thanks Tweakie!
Just for fun, handmade Dot drawing (not mine):
Dátum/Date: Péntek, 2017-12-22, 07:21 | Üzenet/Post # 118 |
That is extremely clever - it shows just how much work DotG does for us
