| DotG software questions, answers in English |
| KisKZ |
Dátum/Date: Szerda, 2011-12-14, 11:49 AM | Üzenet/Post # 1 |
 Generalisszimusz
Üzenetek/Posts: 1982
Hírnév/Fame: 6
Anything about DotG software in English |
| tweakie |
Dátum/Date: Csütörtök, 2011-12-22, 3:05 PM | Üzenet/Post # 2 |
 Ezredes
Üzenetek/Posts: 229
This is my first attempt with DotG, a laser and Mach3 using one of the sample images.
Az üzenetet módosította/Modified by tweakie - Csütörtök, 2011-12-22, 3:06 PM |
| Amatőr |
Dátum/Date: Csütörtök, 2011-12-22, 7:00 PM | Üzenet/Post # 3 |
 Vezér-ezredes
Üzenetek/Posts: 1075
Helyzet/Status: Online |
tweakie, Welcome to Our forum! These laser engravings are awesome, congratulations! Can You tell what laser You're using? Diode or gas? What power?
H1i |
| KisKZ |
Dátum/Date: Csütörtök, 2011-12-22, 7:19 PM | Üzenet/Post # 4 |
 Generalisszimusz
Hírnév/Fame: 6
Quote (tweakie) This is my first attempt with DotG, a laser and Mach3 using one of the sample images.
Hello Tweakie!
Welcome in our forum!
Awesome work! Congartulations!!
Question of Amateur is very good. Please tell us something about your enviroment. I'ts CO2. It's true?
How many time needed for finish a work like this?
Have a nice day! |
| tweakie |
Dátum/Date: Péntek, 2011-12-23, 9:56 AM | Üzenet/Post # 5 |
 Ezredes
Üzenetek/Posts: 229
Hi Guys,
Thank you for the warm welcome.
My machine is home built. It started out as a wood wood router and I added the CO2 laser as an additional tool. Details of the machine are here My WebPage
I have been using a Mach plugin plugin for raster work but there are instances where, I think, DotG will make a better job so I still have a lot of testing to do. Unfortunately the mass of my X Axis is quite high and as a result the acceleration and speed limitation makes DotG quite slow in operation. This in turn means that laser power has to be set near minimum and at a current setting of less than 4mA my laser does not always fire reliably. There is always a challenge.
| tweakie |
Dátum/Date: Péntek, 2011-12-23, 1:33 PM | Üzenet/Post # 6 |
 Ezredes
Üzenetek/Posts: 229
I managed to get this done this morning before the seasonal celebrations start. The image is 115mm x 156mm (chosen because it is similar to the previous DotG example) has been laser cut into an engraving laminate with a stepover of 0.2mm and it took just less than 1 hour to complete Laser power was set at 5mA maximum tube current and my post processor has been adjusted to set the ‘dot’ federate at 2000mm/min and the ‘dash’ federate at 1500mm/min. Although my machine acceleration does not allow the dot federate to get anywhere near 2000 it does vary the burn time sufficiently to start to achieve consistent ‘burn’ results between the dots and the dashes. It is not quite right yet as a lot of detail in the hair has been lost but I am making progress. (don’t know if this make sense ??)
I still have a long way to go before I am fully satisfied with the results but more practicing will have to wait until after the holiday break.
Merry Christmas and a happy, festive, holiday to you all.
| Amatőr |
Dátum/Date: Péntek, 2011-12-23, 3:09 PM | Üzenet/Post # 7 |
 Vezér-ezredes
tweakie, it's great job again! Here comes out the significant difference between laser and mechanical engraving. A similar size picture takes more than four hours to Me with mechanical machining. Quote (tweakie) It is not quite right yet as a lot of detail in the hair has been lost but I am making progress. (don’t know if this make sense ??) Yes, I think it is important to see all details, it will make better impression with the whole image. You can try to set Your machine with some tests, I used this chess-pattern, it shows what to do for the best results. Thank You for info, and I'm also interested about the next tests You will do. I suppose they will be better and better.
Have a Merry Christmas!
H1i |
| KisKZ |
Dátum/Date: Péntek, 2011-12-23, 6:25 PM | Üzenet/Post # 8 |
 Generalisszimusz
Hírnév/Fame: 6
Quote (tweakie) and it took just less than 1 hour to complete
Yes..... This is why lot of peoples are thinking about change to Laser engraving from mechanical machining.
But... I'm tried a 3W diode laser engraver on mirrors. It was approximate same time like mechanical machining. For quick work need more power.
Have a Merry Christmas! |
| tweakie |
Dátum/Date: Kedd, 2011-12-27, 1:32 PM | Üzenet/Post # 9 |
 Ezredes
Üzenetek/Posts: 229
Hi Guys,
Does anyone have an information or details on how they have connected an electromagnet to Mach3 for dot impact ??
This little chap was produced with the laser on MDF and comprises entirely of dots. What I would like to do is reproduce the same image using an impact magnet and then get some comparisons between the two methods from, essentially, the same GCode.
Thanks,
| Viktor |
Dátum/Date: Kedd, 2011-12-27, 3:38 PM | Üzenet/Post # 10 |
 Vezér-őrnagy
Üzenetek/Posts: 320
tweakie, It's wonderful.Gongratulations. |
| tweakie |
Dátum/Date: Kedd, 2011-12-27, 7:40 PM | Üzenet/Post # 11 |
 Ezredes
Üzenetek/Posts: 229
Thank you Guys, you are most kind.
The cat image is 106mm x 130mm and because it comprises entirely of laser dots, theoretically, the same GCode could be used with an impact magnet and again it would take the same amount of time (80 minutes) to complete. Higher resolution and larger images would, of course, take longer but I still have a bit of reserve as far as the speed settings are concerned. It is all a matter of putting theory into practice
I am unable to post the GCode file in .zip format on this forum but for anyone who wishes to reproduce this cat image I have posted the .jpg / .bmp and GCode file I have used here.
| KisKZ |
Dátum/Date: Kedd, 2011-12-27, 7:44 PM | Üzenet/Post # 12 |
 Generalisszimusz
Hírnév/Fame: 6
Quote (tweakie) Does anyone have an information or details on how they have connected an electromagnet to Mach3 for dot impact ??
Hello Tweakie,
Yesterday Viktor and Sanyi84 are spoke about this.
Viktor made a solution for it.
I will ask him for answer, the he or I'm will inform you about this. I need a sort time for it. |
| KisKZ |
Dátum/Date: Kedd, 2011-12-27, 7:59 PM | Üzenet/Post # 13 |
 Generalisszimusz
Hírnév/Fame: 6
tweakie,
I like your work!!! Congratulation!!! |
| KisKZ |
Dátum/Date: Kedd, 2011-12-27, 8:17 PM | Üzenet/Post # 14 |
 Generalisszimusz
Hírnév/Fame: 6
First sorry for my very pure English! I hope you will understand me. If not, please ask me for correction!
What I understood about this yesterday.
Viktor use an unassembled magnetic valve with an hard iron pin in center. For this have an circuit with a nessesary current and voltage. This circuit switched with a relay. This relay got signal from MACH trougth a selected LPT pin. Beni can write a nessesary postprocessor. Victor use now coolant pin, and Beni made change for it on postprocessor.
Sanyi84 told: It is not so good solution, because relay can burn in very early.
Sanyi84 have idea about an elektronic circuit solution using a FET for turn on and off power of magnetic valve (or a solenoid). Yesterday night he work on it.
I will ask he for a picture or a schematic of this circuit. |
| tweakie |
Dátum/Date: Szerda, 2011-12-28, 10:45 AM | Üzenet/Post # 15 |
 Ezredes
Üzenetek/Posts: 229
Quote (KisKZ) Viktor use an unassembled magnetic valve with an hard iron pin in center. For this have an circuit with a nessesary current and voltage. This circuit switched with a relay. This relay got signal from MACH trougth a selected LPT pin. Beni can write a nessesary postprocessor. Victor use now coolant pin, and Beni made change for it on postprocessor.
Thank you, I would be most grateful for any details or schematics.
