Műanyag munkák
Dátum/Date: Szerda, 2011-02-02, 21:59 | Üzenet/Post # 1 |
Üzenetek/Posts: 3074
Kapcsolódó topicok: Lithonapes (Angol) Gravírtűk |
Dátum/Date: Péntek, 2012-12-28, 18:09 | Üzenet/Post # 161 |
Üzenetek/Posts: 1036
Hi Vasspisti,
Thank you for your kind words. I will obtain some polystyrene and see how that turns out.
I am uncertain as to the best method but the above work was produced at a constant X axis velocity of 3,500 mm/min with the laser pulsed at a constant 12.5 kHz with variable PWM (pulse width). This produced a series of overlapping ‘dots’ with a horizontal spacing of approx. 0.0046 mm in the background areas.
Maybe increasing the pulse frequency or perhaps reducing the axis velocity may reduce the unwanted ‘noise’ but this is something I will have to try.
An alternative method would be to keep a constant laser pulse width (PWM) and vary the PRF (pulse repetition frequency). Again, something I will have to try.
Dátum/Date: Péntek, 2012-12-28, 18:17 | Üzenet/Post # 162 |
(tweakie) As mentioned previously, my results with laser cutting lithophanes are extremely poor
Khmm.... I do not think so! I'm thinink about it like Vasspisti!
For hungarian users:
Srácok! Ha gond lenne Tweakie segítségének lefordításával kérlek szóljatok! |
Dátum/Date: Péntek, 2012-12-28, 18:26 | Üzenet/Post # 163 |
(tweakie) This produced a series of overlapping ‘dots’ with a horizontal spacing of approx. 0.0046 mm in the background areas.
Do not have any possibility to synchronise travel speed (step frequency) and laser controll pulse frequency? |
Dátum/Date: Péntek, 2012-12-28, 18:58 | Üzenet/Post # 164 |
Hi KisKZ,
That would work well with a 1 bit image but would require some thought as it may not be possible to do with an 8 bit image whilst still maintaining a constant velocity of X axis travel. (one day we will have PC's that are truly fast enough to make this possible but for the moment I only have a basic machine PC )
Dátum/Date: Péntek, 2012-12-28, 19:12 | Üzenet/Post # 165 |
(tweakie) but would require some thought as it may not be possible to do with an 8 bit image whilst still maintaining a constant velocity of X axis trave
I'm undersand... These lithos are not so nice from 1bit image. But these small noises are not too big as I see.
Great work it, with these! |
ronihun0385 |
Dátum/Date: Péntek, 2012-12-28, 19:52 | Üzenet/Post # 166 |
Pabló, Vasspisti, KisKZ, köszönöm a dicséretet, (Vasspisti) 2,5 a szerszámpálya készítésénél megadott maximális mélység? 2.7mm
www.cncfafaragas.hu |
Dátum/Date: Péntek, 2012-12-28, 21:44 | Üzenet/Post # 167 |
Üdv mindenkinek !
MA MEGSZÜLETETT AZ ELSŐ LITOPAN-om !!!!!!!!!!!!!!! :facepalm: :facepalm: :facepalm:
Méret : 120x90mm + 8mm keret. 30' maró , 1200mm/perc seb. 0.15 lépés. munkaidő :1óra 45perc + a kipucolás ami még nem tökéletes. Portré : a legkisebb unokám.
világítás nélkül:
világítva:
Miki-bá
Az üzenetet módosította/Modified by miki-bá - Péntek, 2012-12-28, 21:46 |
Dátum/Date: Péntek, 2012-12-28, 21:53 | Üzenet/Post # 168 |
miki-bá, nagyon szuper. bánom hogy én nem vettem. |
Dátum/Date: Péntek, 2012-12-28, 22:05 | Üzenet/Post # 169 |
(miki-bá) AZ ELSŐ LITOPAN-om !!!!!!!!!!!!!!
Ez hatalmaaas!!!
Gratulálok Miki-bá!! |
Dátum/Date: Péntek, 2012-12-28, 22:09 | Üzenet/Post # 170 |
KisKZ, Helló ! Hová lett a képem?
Na .... azért !
Az üzenetet módosította/Modified by miki-bá - Péntek, 2012-12-28, 22:09 |
Dátum/Date: Péntek, 2012-12-28, 22:11 | Üzenet/Post # 171 |
(kymco1) nagyon szuper. bánom hogy én nem vettem.
Nyugalom! Beérkezett a zx100 is. NEm tudom mikor jutopk a postára de igyekezni fogok!
Mélben kérném a címedet! |
Dátum/Date: Péntek, 2012-12-28, 22:14 | Üzenet/Post # 172 |
Bettettem az első hozzászólásodba! |
Vasspisti |
Dátum/Date: Péntek, 2012-12-28, 22:33 | Üzenet/Post # 173 |
Üzenetek/Posts: 81
Hello Tweakie,
(tweakie) may reduce the unwanted ‘noise’
Is this noise the mistake of the Laser?
In my experience, the grey scale - toolpaths conversion is very sensitive process. It means, that two areas of the picture seem very same by your eyes, but after engraving you can see differences not before. One of my lithopanes had similar problem as yours, but I have not got Laser, I use spindle machining. I draw a picture and the background was absolute white. I saved it and imported to make toolpaths as usually. After engraving I found discolours instead of flat, white surface. What happened? I made the picture in Paint and saved it in Jpeg format not in BMP. What is the difference?
I made an example:
At the first picture there is a circle. If I save it in Jpeg and in BMP format and reopen them, there are no any differences by eyes:
If I open the picture saved in BMP format and I fill the white areas with red colors, that the result as expected:
If I open the picture saved in Jpeg format and I fill the white areas with red colors, that the result is the next:
It seems, some pixels are no more absolute white in Jpeg format and after engraving the difference will appear.
I think, it is better to use BMP format instead of Jpeg.
Vasspisti |
Dátum/Date: Péntek, 2012-12-28, 23:36 | Üzenet/Post # 174 |
(tweakie) I am uncertain as to the best method but the above work was produced at a constant X axis velocity of 3,500 mm/min with the laser pulsed at a constant 12.5 kHz with variable PWM (pulse width). This produced a series of overlapping ‘dots’ with a horizontal spacing of approx. 0.0046 mm in the background areas.
Tweakie! Can you explain it with a small sketch? It is not absolutely clear for me now. (maybe only because my wrong English)
Just a very simle skecth. |
Dátum/Date: Péntek, 2012-12-28, 23:50 | Üzenet/Post # 175 |
(Vasspisti) Is this noise the mistake of the Laser?
De közben azt hiszem mégis kezdem érteni/sejteni.
Nem a képekkel van a problémája, hanem a lézer impulzus és a sebesség egymáshoz képest való "eltolódásával". Ennél a sebességnél amit használ mondjuk 1mm távolságra nem egész számú pont jön ki, hanem a végeken töredék pontok jönnek ki. Az alapanyagként használt digitális kép ugye egységnyi távolságra mindig azonos képpontot használ. A sebesség és az impulzusfrekvencia együttesen nem pont ezeket a pontokat fedi le ezért bizonyos periodikus helyeken hibás pontok, átfedő részek jönnek létre.
Még mindig nincs teljesen előttem hogy ez hogyan néz ki, de remélem Tweakie tud készíteni egy skiccet hogy jobban lássuk.
A Te általad leírt dolog is fontos, hiszen ott a jpeg tömörítés adta képhibákról írsz és ezt érdemes elkerülni ha lehet egy másik, lehetőleg tömörítetlen formátum használatával, vagy ha mondjuk a fényképeződ mindenképpen JPG-t készítene a lehető legalacsonyabb tömörítéssel menteni a képet.
A BMP mellett érdemes a TIFF-et használni még, szintén tömörítetlen formátumban.
Sajnos egy már erősen tömörített JPG-t nem nagyon lehet javítani. Persze hogy sok esetben a szép képeket ilyen formátumban találja meg az ember a NET-en. Ha szerencséje van az embernek akkor nagy felbontásban kerül a keze közé. Ez egy picit javít a helyzeten, hiszen a tömörítés egy-egy pixel környékén történik, és minél kisebb egy pixel a teljes képhez, annál kisebb a tömörítés zaja is. |
TesztElek |
Dátum/Date: Szombat, 2012-12-29, 00:38 | Üzenet/Post # 176 |
Üzenetek/Posts: 187
Vasspisti@
Köszönöm a segítséget!
kymco1@
400watt kell hozzá |
Vasspisti |
Dátum/Date: Szombat, 2012-12-29, 09:12 | Üzenet/Post # 177 |
Üzenetek/Posts: 81
(miki-bá) MA MEGSZÜLETETT AZ ELSŐ LITOPAN-om
Nagyon jó lett Miki bá, gratulálok! A tisztításhoz fogkefét ajánlok.Hozzáadva (2012-12-29, 09:12) ---------------------------------------------
(KisKZ) Nem a képekkel van a problémája
Lehetséges, részemről csak egy tipp volt, illetve a saját tapasztalatomat osztottam meg, hogy mások elkerülhessék az én hibámat. Tweakie írását még én is emésztem. |
Dátum/Date: Szombat, 2012-12-29, 09:59 | Üzenet/Post # 178 |
(Vasspisti) illetve a saját tapasztalatomat osztottam meg, hogy mások elkerülhessék az én hibámat.
De nagyon jól tetted! Köszönjük Pisti! |
Vasspisti |
Dátum/Date: Szombat, 2012-12-29, 12:59 | Üzenet/Post # 179 |
Üzenetek/Posts: 81
(KisKZ) átfedő részek jönnek létre
Az átfedést (overlapping) én úgy értelmeztem, hogy a lézer 12,5 kHz frekvenciával van működtetve, vagyis két bekapcsolás között 0,0048 másodperc telik el. A 3500 mm/perc sebességgel mozgó X tengely ennyi idő alatt 0,004667 mm távolságot tesz meg, vagyis a két egymást követő lézersugár ekkora eltéréssel fedi le a megmunkált felületet. De azt még nem értem, hogyan okozhatja ez az említett hibát. A képet nézve, én először azt hittem, hogy a fekete területek a problémásak, de ez a lithopane esetében azt jelenti, hogy ott vastagabb az anyag. Lehet, hogy a világos részek a gondok és az átfedés miatt több anyag lett elszublimálva, mint a tervezett?Hozzáadva (2012-12-29, 12:59) ---------------------------------------------
(TesztElek) Köszönöm a segítséget!
Tweakie lesz az igazi segítség a témában, nála megvan a tapasztalat, a berendezés és a kísérletezés is. |
Dátum/Date: Szombat, 2012-12-29, 13:06 | Üzenet/Post # 180 |
Hi Guys,
Re – my earlier posting relating to a laser produced lithophane.
This is what I think is happening (but it is open to debate)…
1) Assuming the background is free of artefacts and all of the same pixel value then the intended tool-path is a series of overlapping dots with similar power density (Fig.1).
2) My machine axis will only move in multiples of the setting ‘steps per unit’ so the exact spacing of the overlapping dots will vary.
3) The output beam from the laser tube has a ‘bell-shaped’ or Gaussian power density similar to the graph shown in Fig.2.
4) The resultant work background surface produced is not smooth - it is a series of spikes and craters (Fig.3).
5) Although the opal Acrylic sublimates there is a residual powder (probably the filler that is used to make the material opaque). I am using a moderate pressure ‘air-assist’ which clears this powder from the work surface, however, any small particles remaining may affect the laser power density.
It is difficult for me to photograph the background surface but it is the small spikes (showing brighter white in colour) which seem top be spoiling the work.
There are still so many unknowns at the moment so it is difficult to decide on the best direction to proceed. As Vasspisti has mentioned image compression techniques produce artefacts and this may well be the cause – more experimentation is definitely necessary.
